Will a noncarb catalytic throw a code? Fixing P0420
Old 29 Jan 2017, 12:43 am
Default Will a noncarb catalytic throw a code? Fixing P0420
Hello all,
My 2004 Pt Cruiser Basenhas been giving me a P0420 code (Catalytic system efficiency below threshold. BANK 1) for a while now. Actually, about 8 months now. i want to replace the catalytic converter with a NON CARB universal one.
My question is will I get an error code if I use one of these cats? I believe the car in question uses CA specs. I myself live in Washington State.
Old 29 Jan 2017, 03:45 am
Default Re: Will a noncarb catalytic throw a code? Fixing P0420
Originally Posted by thisisanoriginalusername View Post
Hello all,
These have the sensor go bad. Have you tried that first?
Old 29 Jan 2017, 08:38 pm
@Buster_PT: You mean the O2 sensor? They seem to be fine. This is actually the second cat on this car though. It's lasted for about 100k. The first one was fouled up because the previous owner messed it up and had oil getting to the original cat.
Old 29 Jan 2017, 09:20 pm
How did you fix it so the oil didn't get into the second CAT?
Old 29 Jan 2017, 10:40 pm
i didn't fix it myself and this was over 100k ago. I had a mechanic fix it at the time but I think it was (and don't quote me on this) the exhaust manifold that was letting oil go through.
Old 30 Jan 2017, 12:22 am
You must have seen the smoke coming out of the tail pipe if the exhaust manifold was letting oil go through?
Old 30 Jan 2017, 02:27 am
Well, I don't remember because it was many years (and miles!) ago but that was for the first cat. This time there is no smoke coming out of the tailpipe. It's just the code. I'm worried that if I use a non carb cat I will get some sort of code too.
code p0420 aarOneShot General Turbo Discussions 5 13 May 2016 06:40 am
Code P0420 - Cat Efficiency lytebulb Tech & Performance Forum 2 08 Jan 2016 08:09 am
P0420 catalytic converter = Potato in Exhaust Sarasmiles Tech & Performance Forum 7 28 Feb 2015 10:40 pm
P0420 code Converter Code? 2008/110,000 miles Sarasmiles Tech & Performance Forum 8 28 Mar 2014 07:08 pm
P0420 code, Much needed help!! Cruisergirl1 General PT Cruiser Discussions 1 15 Oct 2012 04:45 pm
