Timing Belt Replacement
Like Tree4Likes
  • 2 Post By dsab
  • 1 Post By CREWZIN
  • 1 Post By Imakenocents
Old 29 Jan 2017, 11:40 pm
Default Timing Belt Replacement
So I bought my 2002 PT the beginning of December and was going to take some time off in March to replace the timing belt and a whole list of other things. Well the car didn't want to wait. Thursday the timing belt quit so this weekend I replace it and the related components.
The total job isn't quit done as I need/want to replace some other things while I have it apart. These are the torque struts, they are shot and the engine mount.
I''ll also be doing belts, tensioner, and hoses. The parts will be delivered on the 1st so I plan on taking Wed and Thurs off to finish everything up
I've done timing belts/chains in the past and I'm either a bit rusty or this is actually the worst timing belt job I've ever done.
I did start the car tonight and it seems to run just fine. I wasn't able to let it run too long or run the RPMs up much as I was only running off the battery and the engine is supported on a jack.
rckstein and VsandFords like this.
2002 Limited Edition 2.4 Auto with 177k Miles
Old 30 Jan 2017, 07:56 am
Default Re: Timing Belt Replacement
One of the tell-tale signs of doing it right is a smooth idle. If you have that, take a step back and pat yourself on the back.
VsandFords likes this.
Old 30 Jan 2017, 09:08 am
Wink Re: Timing Belt Replacement
Good job! I have a few of these 2002's and yes the timing belt is a tedious job but you seem to have conquered the quest. I have a special needs daughter that lives in a Prader-Willie home at Oconomowoc, Wi. We travel back and forth there at least once a month to visit.
chuzz likes this.
Timing belt replacement snakepitt1 Tech & Performance Forum 10 18 Dec 2016 12:17 am
Timing Belt Replacement.... PTMinotaur PT Cruiser Convertible Forum 9 10 Mar 2016 10:06 am
Timing Belt Replacement JimmH General PT Cruiser Discussions 17 12 Oct 2014 07:49 pm
Timing Belt Replacement JimmH Tech & Performance Forum 0 10 Oct 2014 09:06 am
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
