PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/tech-performance-forum/)
-   -   Srt gauge cluster in PT cruiser (http://www.ptcruiserlinks.com/forum/tech-performance-forum/62708-srt-gauge-cluster-pt-cruiser.html)
kcabe1 30 Jan 2017 02:40 pm
Would they fit? Would they work with the GT ecu? Does it have the same plug as the OEM PT gauge? sorry for posting so many threads on the forum but I just have a lot of questions.
Handy_Cruiser 30 Jan 2017 02:51 pm
Re: Srt gauge cluster in PT cruiser
Cool idea. I assume your are talking about an SRT4 Neon cluster and not the cluster from an SRT Charger, Challenger or 300.
But sadly, no. Not only is it a completely different fit, but the cluster in the PT also contains the Body Control Module (BCM). While likely similar to the PT, the Neon BCM is probably going to cause a lot of 2nd-order compatibility problem. If installing a PT GT cluster in an NA PT causes issues (I once attempted that), the SRT4 Neon cluster will most certainly do the same. ;)
rob302 30 Jan 2017 02:53 pm
1 Attachment(s)
it would not even almost fit. the connector is in a different location. the connector on the PT is molded into the dash plastic.
nothing with that cluster would fit. even if the instrument panel did, the bezel around it would have 3 big holes instead of the neons 2
___________
it seems like you secretly want an srt4 neon. you might consider swapping a whole neon dash into the PT, painting it black, and then adding the SRT cluster
Attachment 20342
rob302 30 Jan 2017 02:56 pm
https://www.youtube.com/watch?v=MktIKfW53Ys
kcabe1 31 Jan 2017 12:00 am
What I really want is a sleeper. I'll probably just use my old gauges, but I don't know if the N/A cluster is compatible with the srt4 ecu.
Busted_PT 31 Jan 2017 06:52 pm
You must first see if it will accept your vin# if not it's all for not. :cool:
