P1604 and P0622
Like Tree2Likes
Old 03 Feb 2017, 09:53 pm
Default P1604 and P0622
Help! I was driving my wife's '03 Cruiser (2.4L non-turbo) home from work today. I stopped in a store, came back out, when i tried to start it, it turned over but didn't start. Tried again, same thing. Tried a third time, same thing and a pop (backfire?). Fourth time it started; check engine light came on. Throwing codes P1604 and P0622.
Not sure if related, but I know that over the past few weeks, when I've used the car's alarm to find it in the parking lot, the chirps have been getting fainter and fainter.
finally, I'm seeing the check oil light come on at idle (sometimes); it goes away when I give it some gas (whether in Drive or neutral).
Any thoughts? Are these related to one another?
Old 04 Feb 2017, 11:05 am
rob302's Avatar
Default Re: P1604 and P0622
i would have the battery tested, clean and inspect the cables, and see if the wiring is oily at the computer. sometimes the oil pressure switch can leak and force oil through the sensor connector, into the wiring harness, and up near the computer, which could cause poor connections and a weird issue like you describe.
just a(n educated) guess.... since for some reason you have 30 views and no replies
Old 04 Feb 2017, 01:30 pm
I agree with Rob about the battery. And I'd also have the alternator checked. If you go to Autozone or O'Reilly, they'll do a complete charging system test for you in the car. No need to remove parts. And that damned oil pressure switch leak up the wire is not that common, but just common enough that the suggestion to check it is a damn good one.
Ignorance can be educated, crazy can be medicated, but there IS no cure for stupid.
Old 05 Feb 2017, 12:20 am
Thanks, guys. I'll check it out tomorrow and report back.
Old 05 Feb 2017, 05:45 pm
Okay - battery cables have some corrosion, which is surprising since they were replace about a year ago. All lines into the PCM are clean and free of oil. Going to jump start it and head to autozone.
Old 05 Feb 2017, 08:15 pm
Odin's Avatar
The oil light going on and off definitely sounds like the the oil pressure sensor. Mine did the same thing. Under acceleration the light goes off, but went on when coasting or braking.
Old 05 Feb 2017, 10:52 pm
Okay; Autozone says bad battery, good alternator. We will replace battery tomorrow.
Old 05 Feb 2017, 10:53 pm
Odin, where is that sensor? I've noticed a minor oil leak; wonder if that is related.
Old 05 Feb 2017, 11:36 pm
rob302's Avatar
It's in the back of the engine. Here's a picture HOW TO: oil pressure sensor replacement
Fk5 likes this.
Old 05 Feb 2017, 11:44 pm
Odin's Avatar
It's on the back of the engine, about half way up and a little to the driver side. You can really only see it from underneath. Look for a yellow connector. Here is a video that helped me when I did it. Also, a 3 inch extension for the 1/2 inch ratchet made removing and replacing the sensor a ton easier.
https://youtu.be/XaoeZDmTjvc
This topic has a good diagram as well.
Oil Pressure Light?
Fk5 likes this.
New alternator not charging, how to check ECM? P0622 imalittleturt Tech & Performance Forum 20 19 May 2018 12:41 pm
Codes P0480, P0622 - seems erratic Jester1 Turbo Performance 10 26 Aug 2017 12:03 pm
P0622 Code and Battery light on!! Mike0x4u General Turbo Discussions 24 11 Jan 2017 09:21 pm
