2007 PT Cruiser key fobs both stopped working
Old 06 Feb 2017, 07:06 pm
LM3 LM3 is offline
Default 2007 PT Cruiser key fobs both stopped working
Batteries are good. What can cause them both to stop opening?
Can't lock or unlock. with buttons.
Old 06 Feb 2017, 07:20 pm
LionPT's Avatar
Default Re: 2007 PT Cruiser key fobs both stopped working
Check fuse #10
Old 06 Feb 2017, 07:24 pm
rckstein's Avatar
Does the alarm button on the fobs work to sound the horm?
Old 06 Feb 2017, 07:48 pm
LM3 LM3 is offline
No and the fuses are fine.
Old 06 Feb 2017, 07:59 pm
rckstein's Avatar
Take your fobs to a place that cuts keys or a battery display in a store, some have a tester that can tell if your fob is sending out a signal.
Old 06 Feb 2017, 08:09 pm
LM3 LM3 is offline
What are the odds of both going up at the same time?
Old 06 Feb 2017, 08:11 pm
rckstein's Avatar
Who knows, both batteries went in both of mine at the same time. But you need to find out first if the fob is working or not before you start tearing into the vehicle. What year and model PT do you have?
Old 06 Feb 2017, 08:12 pm
LM3 LM3 is offline
Batteries are good.
Old 09 Apr 2018, 02:39 pm
Did you ever find/fix the problem?
Old 10 Apr 2018, 10:15 pm
My remote started working intermittently, then not at all. Took the fob apart, cleaned everything with electronics cleaner (CRC QD), retensioned the metal battery contacts (especially the one that makes the connection to the main board) and all worked fine after reassembly.
Of course be sure you reinsert the batteries with the correct polarity.
Here's a good video that shows the whole process.
2004 Chrysler PT Cruiser Limited Edition Platinum Series 2.4L 4cyl Turbo
2005 PT Dream Cruiser - Brake and Tail Lights Stopped Working ArkansasTraveler General PT Cruiser Discussions 5 10 Aug 2015 07:42 pm
analog clock pt cruiser 2008 stopped working naman2015 Interior Accessories Forum 3 24 Apr 2015 12:41 pm
Speedometer jumping, fobs not working Gabriella General PT Cruiser Discussions 6 08 Dec 2010 07:10 pm
My ac stopped working. Help!!! salena Tech & Performance Forum 3 14 Oct 2009 10:56 pm
