oil light has been coming on
Like Tree2Likes
  • 1 Post By NitroPT
  • 1 Post By rcktpwrd
Old 07 Feb 2017, 11:56 pm
Default oil light has been coming on
ive got a 2003 non turbo 5 speed. it has 137k miles. this past 3 days after the engine warms up(im in north Carolina) the oil pressure light flickers and buzzes at idle. or 800-900 rpm. ive changed the oil as it did it 2 times before plus the oil was dirty. if I take the rpms about 11oo light goes out. I was going to check the wire and make sure its clean. wht else should I do?
I should not that I did change the clutch 4 k miles ago. we got the pt in aug and in sept the clutch went and it sat for 2 months before I could get to it. it runs fine
ive got 5w30 in there
I was gonna order a new sender but I want to get some advice first
Old 08 Feb 2017, 12:10 am
Default Re: oil light has been coming on
oil level is good and has less than 300 miles
Old 08 Feb 2017, 02:22 am
_PTGT03's Avatar
use a pressure gauge as a method to test oil pressure specification at idle speed (750rpm)
it can be installed in place of the oil switch, you need to determine the thread size of the oil sending switch so it can thread into the hole.
if measurement is within calibration, your oil pressure switch is out.
but an oil switch is far cheaper than the fitting and testing instrument required to measure specification oil pressure. you may just want to order one and install it to test as well.
you would have to look up the alldata for specifications on your non-turbo engine.
this is something you want to be absolutely sure of, as problems with oil pressure can indicate an engine about to fail
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 08 Feb 2017, 09:54 am
We (the shop and myself) often change oil pressure senders and keep them on hand for this common occurrence with a few Chrysler model vehicles. There are also many TSB about this.
Old 08 Feb 2017, 11:04 am
i read 4 pounds at idle for the non turbo 2.4.no load.
is that correct
I hope the engine is not going out. I so do not need it to break down.
if the switch is good, how would I find out if the oil pump is the problem or engine
if the oil pump is failing, where should I get a new one ie what brand.
Old 08 Feb 2017, 11:37 am
There are new oil pumps available aftermarket. I doubt that your pump is failing knowing how they are engineered as well it would be rare.
Your testing should be with a manual gauge and both idle and 3000 RPM.
4psi at idle is normal
Old 08 Feb 2017, 04:42 pm
rcktpwrd's Avatar
Cool Re: oil light has been coming on
a new oil pressure sensor can be had from RockAuto for a bit over 6 bucks...
2003 CHRYSLER PT CRUISER 2.4L L4 Oil Pressure Sender / Switch | RockAuto
cheap enough to sway out and see if that quiets the dash light.
NitroPT likes this.
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS
www.rcktpwrd.com
Old 08 Feb 2017, 04:54 pm
rcktpwrd's Avatar
forgot to add, don't forget to use the 5% discount code to make it slightly cheaper still...
put this number in the how did you hear about us box: 5699786650844954
Joel
www.rcktpwrd.com
Oil pressure light is coming on car won't run SweetGt Tech & Performance Forum 5 17 Mar 2014 03:03 pm
Oil light coming on, but I have oil PuterChickFL Tech & Performance Forum 25 07 Nov 2013 07:56 am
Low Oil Light Coming On! akasurf General PT Cruiser Discussions 2 08 May 2012 01:24 pm
HELP! Just got oil changed--now oil light keeps coming on! ljpriano Tech & Performance Forum 2 25 Mar 2009 07:35 pm
Airbag light coming on SuzCruz Tech & Performance Forum 14 24 Oct 2007 08:11 pm
