Transmission pan covered in fluid.
  • 1 Post By JoeX
Old 16 Feb 2017, 05:37 pm
Default Transmission pan covered in fluid.
Hello everyone!
We have an PT Cruiser since 2003 and as we expected, started to show some problems. Yesterday I notice small fluid spots under the driver front wheel, so I check and I found the pan looking like this:
Seems like a leak and Im going to take it to the mechanic, but I don't know what to expect. Is only matter of replacing the seals or I have to expect something more complicated than that?
Thanks in advance!
Old 16 Feb 2017, 07:23 pm
rsrocket1's Avatar
Default Re: Transmission pan covered in fluid.
FYI replacing the transmission oil pan is very easy. Just remove the bolts all around and put a new one in. You'll also probably need to carefully scrape away the old gasket sealer goop and put in a new gasket. The Doorman pan at Rock Auto is only $25 and does not include a gasket. Gaskets are often included with ATF filters which cost $5-$12 also at Rock Auto. The Doorman pan has a drain plug so the next time you want to drain the ATF, you don't have to remove the pan.
You can also get a hand pump at Harbor Freight for $7 to drain most of the fluid out through the dipstick neck before you remove the old pan. It makes for a much cleaner replacement.
After removing the pan, look at the magnet and see if there are any big metal chips (bad). Small "filings" are not bad and are typical.
My ATF Pan replacement story
I don't know if that will fix your problem but you could also clean the area with some Simple Green or 409 and check again in a day or so to see if the ATF pan seal is the problem or if the leak starts elsewhere.
Good Luck
Old 16 Feb 2017, 07:59 pm
Transmission solenoid pack and tranny cooling lines are just above the front edge of the pan and should be checked.
rsrocket1 likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 17 Feb 2017, 01:02 pm
I agree with JoeX. I think you should definitely check the solenoid pack.
Ignorance can be educated, crazy can be medicated, but there IS no cure for stupid.
Tags
transmission pan
transmission fluid deafy06 General PT Cruiser Discussions 7 06 Jul 2012 04:28 pm
Will a slipping, nonfunctioning transmission be covered under drivetrain warranty? Rumble Tech & Performance Forum 6 10 Oct 2011 11:10 pm
transmission fluid partyd General PT Cruiser Discussions 7 09 Feb 2011 10:33 pm
Transmission Fluid scatgo Tech & Performance Forum 4 31 May 2009 09:04 pm
Transmission Fluid DaShado Tech & Performance Forum 1 02 Jul 2007 06:18 pm
