06 PT cranks no start
Like Tree7Likes
Old 18 Feb 2017, 01:24 pm
Default 06 PT cranks no start
06 pt now turbo auto..130k,,when you try to start it it cranks over few times then stops? cant get the codes cause i thought it may be the PCM? so I disconnected the battery before thinking to get them..so now no codes..
anyway to get them after a disconnect? I had problems with the key switch getting stuck on and couldnt get the key out,,so I put a dab of lube on the key and it seemed to help no more sticking..
but would the switch go bad and cause the no start? cranks a few times then stops? maybe a dealer trip to run a scann? I was thinking the switch or the PCM went out?
Old 18 Feb 2017, 02:01 pm
Default Re: 06 PT cranks no start
First thing I would suggest is to make sure you have enough voltage to get spark when you are cranking so do a battery load test. Check all cable connectors and make sure they are making good contact. Since your engine is not running check the battery itself. The link below will help you check the battery.
Nitro's way of checking a battery
Is your security little red light constantly on when you are cranking the engine?
Other parts of your ignition switch is your ignition actuator and the small rod that goes between the ignition cylinder and the ignition actuator. You might have an issue there but you need to do a complete diagnosis before looking at the ignition switch. You can check to see if you have the proper voltage coming from the ignition switch by measuring the voltage on the little wire going to the starter.
Old 18 Feb 2017, 04:30 pm
_PTGT03's Avatar
cranks but no starts and similar problems can be complex with a number of variables. but first thing is to start with the obvious.
as you put the key to crank position the starter should just keep turning as long as the battery gives enough juice.
i suggest hooking up a charger to your battery and then trying to crank the engine again.
get a multi-meter and set it to the 'min-max' function and check the minimum voltage while cranking, it should not get below 10.0 volts. if it does, have your battery replaced.
Old 19 Feb 2017, 12:45 am
thanks guys I came home tonight,working 6 days..and tryed to turn it over battery was dead as a door nail,,I"m betting on a bad Battery I"m gonna check it tomorrow.I pray it is lol..cause I got other issues that need attention..thank you guys for your info.I will let you know
Old 19 Feb 2017, 04:55 pm
put a good charge on the battery and it now turns over good stutters but wont start..I checked the timing belts its not broke..check engine light is on but will not throw a code? tryed the key deal and my scanner no codes? PCM?..cam sensor?..
Old 19 Feb 2017, 05:26 pm
I would suggest spraying some starter fluid in the throttle body with it open to see if it starts to run. If so its time to check your fuel pressure.
If it does not start to run then take a spark tester and see if you are getting spark. If no spark check your ASD fuse.
Old 19 Feb 2017, 05:29 pm
I did still no start..swamped cam sensor out with good one still no start
Old 19 Feb 2017, 05:35 pm
I would suggest checking for spark. Sometimes the crankshaft sensor does not trigger the PCM to put out the code for it.
Old 19 Feb 2017, 05:41 pm
_PTGT03's Avatar
the crankshaft position sensor will be the unit to look at. cam sensor has nothing to do with starting.
observe the tachometer when cranking. if the needle does not move, you have a problem with the circuit to the CKP sensor or the sensor itself.
if you can confirm circuit and sensor, next is to move onto the PCM.
Old 19 Feb 2017, 05:50 pm
Teach gos to about 500 rpm when I crank it
The cranks but doesn't start!!! Ashjoes616 Tech & Performance Forum 6 01 Jan 2017 09:38 pm
Cranks but no start? C300392 Tech & Performance Forum 4 15 Apr 2016 07:58 am
Cranks, won't start (bad PCM ???) dxv77 General PT Cruiser Discussions 14 26 Jul 2015 05:19 pm
05 PT cranks but won't start. Noah1 Tech & Performance Forum 5 22 Jan 2015 03:38 am
Cranks but want start stickkman99 General PT Cruiser Discussions 8 04 Aug 2013 12:00 am
