Power Steering Pump?!
Old 18 Feb 2017, 07:41 pm
Default Power Steering Pump?!
I bought my beautiful 2001 PT Cruiser in June 2016 but had to replace the power steering hose a month later when turning the steering wheel became incredibly loud and difficult. Everything had been going well after that replacement until yesterday. I got the car's battery replaced and got the oil changed, but the mechanics said they noticed that the power steering was making noise again. I had noticed it the past few weeks, but the noise is still very faint--nothing like the atrocious noises from this summer. I've checked the power steering fluid and it's completely filled up, so I don't think there's a leak in the hose, which makes me think it might have something to do with the pump? The noise is still relatively quiet and turning the wheel isn't troublesome. It also doesn't become audible until I've already been driving for several minutes, meaning it's silent for the beginning of each trip. I'm inclined to continue monitoring the situation until it worsens...? Any ideas or suggestions? Thanks so much!!!
Old 18 Feb 2017, 09:12 pm
Default Re: Power Steering Pump?!
Welcome to the forum.
Old 18 Feb 2017, 10:37 pm
_PTGT03's Avatar
Use full synthetic chrysler ATF +4 and use seafoam transtune to flush out the old fluid. that should fix the problem the cheapest way.
Tags
power steering, power steering fluid, power steering hose, power steering pump
Power Steering pump codesguy General Turbo Discussions 0 23 Aug 2016 05:21 pm
Power steering pump GrapeApe Tech & Performance Forum 2 18 Nov 2014 03:39 pm
Power steering pump TexasPTCruisin PT Cruiser News and Rumors 4 23 Nov 2012 04:04 pm
Power Steering Pump?? TurboDucky Tech & Performance Forum 2 28 Mar 2012 08:15 pm
Power Steering Pump Out! lovemyturbo Tech & Performance Forum 4 12 Feb 2011 06:10 am
