3rd & 4th gear grinding
  • 1 Post By rob302
Old 24 Feb 2017, 09:20 am
Default 3rd & 4th gear grinding
This just started. So three days ago the PT started grinding 3rd & 4th gear. Just those two. 1,2,&5 work fine. Put a new clutch in about 40k ago its at 180k, we drive it 3k or less a year now. It's 2001. Any help would be appreciated. If I let the idle all the way down I can get 3rd without grind.
Old 24 Feb 2017, 10:58 am
rob302's Avatar
Default Re: 3rd & 4th gear grinding
mine had a 2-3 grind. i just ignored it, got used to shifting at just the right RPM. i would assume it's a synchro needing replacement and not a clutch issue since it's only the 3-4 shift. since you only drive 3k a year, i would just live with it. the cost effective thing would be a cheap used trans or a rebuild kit and doing it at home, but you'd need a press, splitter, etc.
you should check the fluid level in the trans. not to fix the problem, but as a precaution to avoid it getting worse.
06 GT Cruiser, 5 sp; grinding into 3rd gear Db06gt General Turbo Discussions 7 20 Jul 2016 06:51 pm
AC Fan grinding noise shonenknife Tech & Performance Forum 6 27 Jun 2013 05:59 pm
Another Grinding Noise... bjagd02 Wheels, Tires, Suspension 3 01 Nov 2010 09:01 am
More on grinding wazzzzman General PT Cruiser Discussions 1 06 Mar 2009 02:31 pm
p0733 Gear 3 Incorrect ratio p0733 Gear 3 Incorr RobGT General Turbo Discussions 12 04 Nov 2004 02:02 pm
