mystery wire right of column
Like Tree3Likes
  • 2 Post By rob302
  • 1 Post By bubba_1952
Old 25 Feb 2017, 11:50 am
Default mystery wire right of column
Hi Cruisers. I have a mystery wire that I don't know what it goes to. Prevois owner was under there monkeying around and I spotted this and figured to ask the experts here. This is behind the panel access beneath the steering column. TKS Bart
Old 25 Feb 2017, 12:12 pm
Default Re: mystery wire right of column
1st....while we all may have some expertise to help other members noone I know of is clairvoyant to know what year and model PT Cruiser you have.
Maybe add a signature information to your user name?
So lets start with that. ^^^
General description of mystery connections found on many vehicles manufactured from 1995 and newer.
It is not uncommon to have connectors unused in vehicles. Wire harness usually for the production costs will accommodate all possible variation of components so installation of needed accessory harness is not needed.
Old 25 Feb 2017, 12:32 pm
rob302's Avatar
Can't find where this wire goes
Old 25 Feb 2017, 01:16 pm
bubba_1952's Avatar
Checking my wiring schematics, I see there is a white two wire connector located about there.
It is the 'brake transmission shift interlock solenoid connector'.
If it is this connector, the wire colors are white/pink and light green/black.
From what I read, this connector may be used only on export vehicles.
2004 Limited Edition Platinum Series Dark Graphite Metallic Clearcoat Turbolight A/T
Old 25 Feb 2017, 02:25 pm
Sorry Guys. Its a 2001 and has a five speed. I just pulled a '' GPS Tracker '' thing out from under that area and not even sure what the heck it is. It wasn't hooked to anything but there are two wires that have black tape (I'm assuming that is where it was tied in at one time )
Any way, I spotted the mentioned wire while I was in there. I know sometimes manufacturers have extra wires for things on different models , most likely that is the case here. but I wanted to ask if you had come across this or knew of where it may go (if anywhere)
Old 25 Feb 2017, 02:33 pm
I believe Rob302's post pinned it down. As Bubba 1952 describes, it is there for some exported model reason.
I have a mystery wire hanging by my Muffler? harleyrider421 General PT Cruiser Discussions 6 29 Oct 2015 08:38 pm
P0750 and a little red wire, and a blue wire? gwairbrush General PT Cruiser Discussions 1 20 Jun 2013 06:39 am
Column gauge pod fit Cruiszr General PT Cruiser Discussions 5 02 Nov 2011 08:15 pm
steering column noise 4SPEED General Turbo Discussions 2 12 Sep 2006 03:33 am
First Column turbomangt The Detail Shop 4 29 Apr 2005 06:42 pm
