Under column wire identity
  • 1 Post By Dahoopd
Old 26 Feb 2017, 08:42 pm
Default Under column wire identity
I replaced my ignition switch and can't figure out where this clip plugs up. All of the gears on the shift indicator are lit up. I was hoping this was the problem. There are no other issues with the cluster or lights.
2003 PT Cruiser GT - Hand Me Down from Dear Old Dad / Mods: Lowered - Gauges (Boost, Oil Pressure, Volt, EGT, A/F
Old 26 Feb 2017, 09:11 pm
Default Re: Under column wire identity
mystery wire right of column
Old 26 Feb 2017, 09:45 pm
Originally Posted by quicksilverdon View Post
Crap! Was hoping it was the culprit, thank you for the help.
mystery wire right of column glassbuggy Tech & Performance Forum 5 25 Feb 2017 02:33 pm
Clip Identity Dahoopd Tech & Performance Forum 3 13 Jan 2017 10:49 pm
P0750 and a little red wire, and a blue wire? gwairbrush General PT Cruiser Discussions 1 20 Jun 2013 06:39 am
Idle Surge Of Sorts? Oil Identity? GTCRUISER2006 Tech & Performance Forum 17 30 Jan 2012 06:45 pm
First Column turbomangt The Detail Shop 4 29 Apr 2005 06:42 pm
