Replaced fan still not working
  • 1 Post By LionPT
Old 03 Mar 2017, 12:03 am
Default Replaced fan still not working
Hi everybody I'm new to the group and new to the world of Chrysler I recently bought a 2006 Chrysler PT Cruiser Turbo Limited VIN number 8 I had some overheating issues so I bought a new fan that came with a new fan harness and relays but I'm still having the same problem the fan will not come on when the AC is turned on and it will not come on when the vehicles up the temp for it to come on I checked fuse number 15 and it is good as well I'm 32 years old and have been working on cars since I was seven years old I'm a pretty good mechanic but I usually don't work on cars this new and I have never worked on a turbo car let alone on one till now when I plugged the new harness into the old harness I looked inside I didn't see any moisture or anything burned the wires look good from what I can see I tested the ground and it checked out good I don't think I'm getting any positive signals is there anything else that controls the fan that I missing I sold my car to buy this one and I live 45 minutes from work and haven't been able to make it in all week any help would be very much appreciated thank you all
Old 03 Mar 2017, 01:24 am
Default Re: Replaced fan still not working
Welcome to the forum.
Is your engine light on? If so what are the engine trouble codes?
Did you check to make sure the new fan low and high speed was working properly before installing it?
Did you check fuse #15?
The radiator fan operation is controlled by the Total Integrated Power Module with inputs from the Powertrain Control Module . Inputs for coolant temperature and vehicle speed are sent to the the Powertrain Control Module. This information is then sent via the communication bus to the TIPM which turns on the radiator fans.
Old 03 Mar 2017, 05:49 am
rckstein's Avatar
Don't be surprised if you get some comments on your original post as it is one long sentence. But if you were using a phone to post on, that can happen. Other members on this forum have posting issues, as well.
Old 03 Mar 2017, 06:52 am
LionPT's Avatar
Check the temperature sensor, wire & plug.
Old 03 Mar 2017, 09:51 am
Have you done a pressure test to see if there's a leak? You should try that. And remember to pressure test the radiator cap too. You don't say that you've flushed the cooling system and heater core either. Have you? If you've done all of that and replaced the thermostat, you SHOULD be good to go. One other thing to check though, is the hose running from the radiator filler neck to the overflow jug. If there are cracks or holes in it, it won't operate properly either.
Ignorance can be educated, crazy can be medicated, but there IS no cure for stupid.
Replaced PCMs are not working Knaller17 Tech & Performance Forum 25 20 Dec 2016 06:56 pm
A/C not working after timing belt replaced 1gr8pt Tech & Performance Forum 11 31 Jul 2015 09:30 am
05 Touring turn signals working & not working angel66rose Tech & Performance Forum 5 11 Dec 2013 09:34 am
IOD fuse replaced and still not working sometimes rafysonera General PT Cruiser Discussions 2 12 Apr 2013 01:31 pm
2006 - Replaced Fan - Comperssor Not Working wbwalsh General PT Cruiser Discussions 5 23 Jul 2009 02:33 pm
