My automatic transmission acts as if I'm driving a manual
Like Tree2Likes
  • 1 Post By ptcruisersteve
  • 1 Post By chuzz
Old 05 Mar 2017, 11:13 am
Angry My automatic transmission acts as if I'm driving a manual
Hello all! My 2002 pt cruiser ran fine before it went out. I have 143000 mi on it everything is sound on it. Well maintained. Anyways I was driving home and made it to about a mile from my house and transmission started acting like I was fanning a clutch pedal. Drive train was in and out it revs just doesn't want to engage gears. Only parts replaced recently was an alternator. I flushed tyranny fluid out and it worked for a couple days then back to not engaging drive. Not a significant amount of metal in pan, at least didn't look major only specs. Anyone able to help me?
Old 05 Mar 2017, 01:23 pm
Default Re: My automatic transmission acts as if I'm driving a manual
Is your engine light on? If so what are the codes?
You might get an P0700 trouble code for a generic transmission trouble code and need to take it to a transmission shop where some will scan the transmission codes for free.
Sicx32 likes this.
Old 05 Mar 2017, 03:16 pm
I don't remember honestly. I was hoping something cheap but I bought another pt with a blown head for cheaper than a used tyranny but after taking it out I'm looking for a cheaper option lol. This is my first front wheel drive car. I'm gonna run codes tomorrow and I'll check back with you. Thank you for your help! And yes my engine light is on.
Old 05 Mar 2017, 07:11 pm
You say you flushed the tranny. Did you replace the filter? Sounds to me like it's stopped up for some reason.
Sicx32 likes this.
Old 10 Mar 2017, 03:27 pm
Yes I replaced the filter. I was wondering whether it could be transmission pump?
Old 10 Mar 2017, 11:48 pm
ad an 03 automatic and at 133,000 it slipped twice before actinglike it run out of fluid. Nothing in pan, no visual damage to gears or clutches. Bought a used one, installed and back on the road again..
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 11 Mar 2017, 01:59 am
_PTGT03's Avatar
did you try after flushing with seafoam transtune, and replacing atf fluid with chrysler dextron 4+ and with lucas anti-slip additive ?
Old 11 Mar 2017, 07:07 am
Dude, Chrysler has never produced any type of Dexron transmission fluid. I think you meant Mopar ATF+4, right? General Motors created and copyrighted the Dexron name.
Tags
2002 transmission
Transmission shudder when downshifting on Automatic transmission. Dez512 General PT Cruiser Discussions 15 18 Jun 2014 09:32 am
Transmission stuck in 1st gear 2007 PT Cruiser Touring (Automatic transmission) ProdigyMan Tech & Performance Forum 7 19 Jan 2014 02:51 pm
Reliability-Manual vs. automatic transmission pstar General PT Cruiser Discussions 8 29 Mar 2010 10:36 pm
automatic to manual popes Tech & Performance Forum 1 10 Jun 2008 09:32 am
Automatic, Driving in 3rd ptcignaboi General PT Cruiser Discussions 1 22 Feb 2003 07:37 pm
