Bucking, jerking, cuting out, finally SOLVED
Like Tree12Likes
Old 05 Mar 2017, 06:10 pm
Default Bucking, jerking, cuting out, finally SOLVED
I was having this issue intermittently for a quite long time. Strangely it occurred mostly in the first hour of driving. I replaced a ton of parts with no cure. Here is a link to my post about that: What else can I do before I torch that thing
Then you guys suggested to replace the crankshaft sensor plug. I was skeptical. The plug looked OK to me. To be 100% sure, I decided to do it anyway. There was a lot of black insulating tape around the harness which was suspicious. As I was removing the tape, three red butt connectors came to light. The plug was already once replaced by someone. As I was undoing the rest of the tape, one of the wires broke loose. Upon inspecting the butt connector, it was apparent that only one side of the butt connector was crimped. The other side was not crimped and the wire was loose, giving an intermittent connection. I soldered the three wires on the new connector. I don't like to use crimp connectors on sensitive wiring. That solved it. You guys rock!
2001 PT Cruiser Limited Edition 5-Speed MT, stock. Second owner since 06/2016
Old 05 Mar 2017, 06:14 pm
Default Re: Bucking, jerking, cuting out, finally SOLVED
Nice story. Too bad all that electrical tape wasn't noticed when you first started trouble shooting. Someone did a half a.. job of patching the first sensor.
Old 05 Mar 2017, 06:31 pm
I added your post to the original thread so others can see what the solution was if they come across it. Thanks for coming back and posting what the solution was.
quicksilverdon and Fk5 like this.
rckstein's Avatar
Glad to hear you got it fixed, too bad you had replaced so many other parts, before finding the problem was a $0.10 butt connector not properly installed.
Old 05 Mar 2017, 09:11 pm
I'm gonna check for this the next time I'm under my car in a couple days. I've got some light bucking, jerking and a tiny bit of cutting out occasionally during warm up.
Old 05 Mar 2017, 09:31 pm
Yes, too many do not ever let us know the outcome of their problem - they just disappear.
Old 06 Mar 2017, 10:58 pm
_PTGT03's Avatar
I had this symptom but just bucking/jerking at low speeds. It was the ignition coil. The old ignition coil tested within resistance specifications, so it appeared fine but it really had something wrong with it.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 10 Mar 2017, 05:51 am
Does my 2008 have a crankshaft sensor, and where is it located? I cannot find it in my clymers manual
Old 10 Mar 2017, 05:56 am
rckstein's Avatar
It's below the starter.
Old 10 Mar 2017, 09:43 am
rckstein and LionPT like this.
Jerking and bucking @ 3mph njsmmons Tech & Performance Forum 3 19 Jul 2015 04:29 pm
Misfiring & bucking SOLVED! PT_Mopar Tech & Performance Forum 18 19 May 2014 03:56 pm
Bucking PT dvddmc Tech & Performance Forum 6 10 Jun 2013 10:48 pm
bucking at 1/2 a tank rhell Tech & Performance Forum 4 01 Sep 2010 07:50 am
Bucking bquik Tech & Performance Forum 5 06 May 2010 08:26 pm
