How to change the battery from a 2007 Cabrio
Like Tree3Likes
Old 09 Mar 2017, 04:08 pm
Black_Thunder's Avatar
Question How to change the battery from a 2007 Cabrio
How to change the battery from a 2007 cabrio
I hope someone can help me with this
PTCruiser 2.4/16V Cabrio Black
2007 Manual 5-speed
And God promised men that good and obedient wives would be found in all corners of the world...
Then She made the earth round....
and laughed...and laughed...and laughed...
Old 09 Mar 2017, 04:16 pm
rckstein's Avatar
Default Re: How to change the battery from a 2007 Cabrio
Welcome to the forum
Can it be much different from the US PT's?
Can you post a pic of the engine bay, particularly the battery area?
Old 09 Mar 2017, 04:38 pm
cruserdad1976's Avatar
the battery is under the seat if it is a desiel and I have no idea where it is if its a gas
Old 09 Mar 2017, 04:47 pm
its not a diesel. Ill take a pic tomorrow.Its different from the convertibles
2007 Manual 5-speed
Old 31 Mar 2017, 08:01 am
The pics
Due to a sprained ankle a little bit later than planned
2007 Manual 5-speed
Old 31 Mar 2017, 08:10 am
rckstein's Avatar
In your original post, you deleted your issue when you added the pics.
Are you just wanting to know how to replace the battery?
It's in the same location as the US PT's, so removal/replacement should be the same. You have to remove the airbox cover and then the airbox, to get access to the battery hold down bolt.
Old 31 Mar 2017, 08:24 am
so i disconnect the hose and just pull out the filter box?
No hidden screws?
WARNING: IN THE Below VIDEO, HE DISCONNECTED THE CABLES IN THE WRONG ORDER. DISCONNECT THE NEGATIVE (BLACK) FIRST, THEN THE POSITIVE (RED). THEN WHEN RECONNECTING, CONNECT THE POSITIVE ONE FIRST, THEN THE NEGATIVE.
WARNING: IN THE ABOVE VIDEO, HE DISCONNECTED THE CABLES IN THE WRONG ORDER. DISCONNECT THE NEGATIVE (BLACK) FIRST, THEN THE POSITIVE (RED). THEN WHEN RECONNECTING, CONNECT THE POSITIVE ONE FIRST, THEN THE NEGATIVE.
2007 Manual 5-speed
Old 31 Mar 2017, 08:26 am
rckstein likes this.
Old 31 Mar 2017, 08:28 am
rckstein's Avatar
Correct, no hidden screws on the airbox, it just lifts out as it sits in a rubber bushing. There
may be a hose on the side of the airbox, disconnect that to fully remove the airbox.
The battery hold down bolt will be on the backside of the battery. Remove that and then the battery will be free. Of course, disconnect the cables, the negative one first.
WARNING: IN THE ABOVE VIDEO, HE DISCONNECTED AND RECONNECTED THE CABLES IN THE WRONG ORDER. DISCONNECT THE NEGATIVE (BLACK) FIRST, THEN THE POSITIVE (RED). THEN WHEN RECONNECTING, CONNECT THE POSITIVE ONE FIRST, THEN THE NEGATIVE.
Old 31 Mar 2017, 08:59 am
Thanks
2007 Manual 5-speed
Tags
battery cabrio
Battery change pvjones57 General PT Cruiser Discussions 7 30 Apr 2016 06:38 pm
Vid on how to change the battery WolfmanG General PT Cruiser Discussions 1 30 May 2011 10:08 pm
trying to change battery ??help !! bobs turbo pt General PT Cruiser Discussions 4 20 Feb 2011 05:57 pm
Battery change turbomangt General Turbo Discussions 18 24 Jun 2008 02:58 pm
Chrysler PT Cruiser cabrio skylight PT Cruiser Videos 0 13 Dec 2007 08:00 pm
