Radiator part help- 2003 Turbo - leaking coolant
Like Tree9Likes
Old 12 Mar 2017, 02:28 pm
Default Radiator part help- 2003 Turbo - leaking coolant
First post glad to see a forum for these cars. I am about to purchase from a friend a 2003 woodie turbo and just the radiator is leaking from a part which I cannot for the life of me identify. I am attaching pictures and hope to have some insight provided. Thank you for your time. First photo is the part and the cracked plastic and the second is where it was from
Old 12 Mar 2017, 02:52 pm
rob302's Avatar
Default Re: Radiator part help- 2003 Turbo - leaking coolant
Where are you located?
Old 12 Mar 2017, 02:59 pm
Orlando Florida. After reading the service manual provided on here i have identified the part as the "radiator inlet neck" but cannot find a part number.
Old 12 Mar 2017, 03:05 pm
rob302's Avatar
i have never seen a radiator with a bolt-on inlet like that. a whole radiator is only $60 + shipping though. in my case shipping was cheap. the radiator was fedex'd from a place so close it was picked up and delivered by the same truck for iirc about $8
More Information for TYC 2677
2003 CHRYSLER PT CRUISER 2.4L L4 Turbocharged Radiator | RockAuto
i asked where you were because i have a fairly new radiator i'd give away free if you were in the area.
a few of us have used and are happy with the cheap RA radiator. -> anybody try the $54 radiator
Old 12 Mar 2017, 03:11 pm
Yea we have come to that conclusion as well but what a labor intensive job for a part that sits on top and is bolt on. Just odd they don't have them available online. We checked one U-pull yard and the turbo models all had that part removed so I had assumed it was a commonly replaced or sought after part. A new radiator would have the inlet neck attached?
Old 12 Mar 2017, 03:16 pm
rob302's Avatar
yes. you can buy the cheap radiator. the inlet is just part of it(non removable). took me 1 hour and 40 minutes to change including filling and bleeding..
searching here, it seems that nobody ever found the part you're looking for and the inlet is only sold with the radiator:
Originally Posted by firemedic1560 View Post
Hello everyone,
I am looking for a radiator inlet neck to fit a 2004 2.4 Turbo engine. Even though this part is bolted on to the radiator and is designed to be removed, I was told by two different dealers that it is only sold as part of a complete radiator for a cost of $325. This part is the piece that the upper radiator hose clamps onto. Thanks!
Old 12 Mar 2017, 03:18 pm
Thank you for the help man. By the way could you link to any install guides. Just for tips and suggestions especially considering removing from the intercooler .thank you for the help
Old 12 Mar 2017, 03:24 pm
rob302's Avatar
PM me your email and i'll send you a PDF
rckstein likes this.
Old 12 Mar 2017, 03:33 pm
Thank you sir.
Old 12 Mar 2017, 03:40 pm
rob302's Avatar
i've emailed you. you should have the info you need shortly.
to send a PM in the future, just click my name in the post and choose "send private message"
Brake pad part numbers for 2003 GT PT Turbo Toolman Turbo Wheels/Suspension/Handling 11 12 Jan 2017 06:40 pm
2003 turbo coolant cloudhidd3n General PT Cruiser Discussions 12 07 Mar 2016 09:10 pm
2003 gt turbo coolant lines DODGETHIS General Turbo Discussions 0 24 Jan 2013 09:08 pm
Radiator leaking coolant. NicksCruiser Tech & Performance Forum 7 26 Oct 2012 11:13 pm
2003 GT Turbo leaking some fluid black_vii General PT Cruiser Discussions 7 28 Mar 2012 05:28 pm
