Top 3 Performance mods
Like Tree34Likes
Closed Thread
Old 14 Mar 2017, 12:38 pm
vermontpetey's Avatar
Default Top 3 Performance mods
So to date, I have left the engine/driveline of my PT bone stock. With the other upgrades I'm doing cosmetically, I've been thinking about what performance upgrades might be worth doing as well.
I'm looking for feedback on what might be considered the top 3 performance upgrades to a PT with the turbo-lite. I'm not a mechanic but feel fairly comfortable taking things apart as needed.
Suggestions???
myfuzzydice likes this.
You're never too old to have a happy childhood..
Old 14 Mar 2017, 12:50 pm
Default Re: Top 3 Performance mods
The Top#1 is the Stage 1, if you can find it.
myckee likes this.
Old 14 Mar 2017, 12:57 pm
Better title may have been..
Re: Top 3 Performance mods that *really work!
Not necessarily the easiest depending on the year and model PT.
1. *Custom CAT back exhaust system
2. *PCM performance Calibration
3. *Gasket match Porting Exhaust
The published (motorbooks) Top 3 Performance mods
1. *Performance Air Filter
2. *Ignition upgrades
3. Available retail manufactured Cat back system
What was found to be the commonly reported Top 3 Performance mods
1. Available retail manufactured Cat back system
2. *PCM Stage 1 or equivalent
3. CAI
Top 3 Performance mods that will get the best bang for the bucks spent.
2. *NOS wet system
2. *PCM calibrated from Data Logged information.
SPLNeon likes this.
Old 14 Mar 2017, 01:14 pm
Didn't think about it, but exhaust is already on the way so there's #1. Sounds like the next two easy ones would be the PCM and Intake.
I see several CAI options on the web. Seems like K&N is a common option. Is it a good one?
Who is a good source for a Stage 1 PCM?
Old 14 Mar 2017, 01:28 pm
NOT 1 CAI ever offered for a PT Cruiser Turbo Model really increase the engines output by itself. In fact most of them will reduce your engines output at different levels of the RPM range. Most of the increases may have simply been replacing the air filter with an improved flow version? Viewing DYNO info without SAE smoothing reveals the real truth about reports of increases.
Unless you are planning to do HEAD work the stock "un-modified" box and intake hose to the Turbo is really the best.
However... I personally like the look and the air sound of a simple and inexpensive cone air filter and polished aluminum piping. There are dozens of examples of PT's useing these even CREWZIN NA PT Cruiser pictured in a previous response has one.
The loss of maximum engine output is so insignificant it is not worth even mentioning.
Old 14 Mar 2017, 01:53 pm
PTpreacher and NitroPT like this.
Old 14 Mar 2017, 01:54 pm
Fk5 Fk5 is offline
If you're getting an exhaust and CAI, do the tune after because those mods generally don't add anything without a proper custom tune. As Nitro said, CAI do not add much if anything and can actually hurt. I have been considering one to get some room for water/methanol injection, but things keep need replacing and I have to work on the house, so...
2003 GT 5 speed
162,000 miles
Old 14 Mar 2017, 01:56 pm
1600x899 Big enough?
Old 14 Mar 2017, 02:25 pm
Darn Photobucket! can't tell how big pics are until that load up on the forum then takes ages to get it down to size.
Old 14 Mar 2017, 03:28 pm
Handy_Cruiser's Avatar
Suggestions???
Per CREWZIN's suggestion, the Stage 1 PCM is the easiest and best way to gain as much as 40 hp with only ten minutes work. And they are very cheap considering what they provide. Just find a core PCM and FWD Performance can flash it to a Stage 1 that will be plug and play in your turbo light. And if your are brave and have the time, Sykes ECM Tuning can add even a little more.
It's my belief that this is the first performance upgrade to make on a turbo light. And this should likely be your baseline when you start adding some of the others suggested.
myckee likes this.
Closed Thread
03 PT Gt Help with performance mods.. ttcruiser Tech & Performance Forum 8 04 Apr 2013 11:03 pm
bit of help needed..performance mods 2.0lt johnnysanchez Tech & Performance Forum 2 04 May 2011 07:54 am
performance mods infernodreamcruiser02 Tech & Performance Forum 7 06 Apr 2011 03:53 pm
performance mods bhunt41 Tech & Performance Forum 11 30 Dec 2010 10:35 pm
Cheap Performance Mods? TurboDucky Tech & Performance Forum 6 04 May 2010 04:21 pm
