Bought $450 PT GT engine. Help.
Like Tree15Likes
Old 14 Mar 2017, 12:46 pm
Default Bought $450 PT GT engine. Help.
It has 140,000 miles on it and I need to know what I should replace before I build it up. I know I need to do the timing belt, water pump, and gaskets, but what else?
Old 14 Mar 2017, 01:29 pm
Default Re: Bought $450 PT GT engine. Help.
I just went through this. You already mentioned the mandatory parts. I'll add these to the list:
Pull oil pan - eliminate slop in balancer chain
Consider plastigauging the crank main journal bearings to see where you're at in terms of bearing clearances
Consider installing a new oil pump
Front and rear main oil seals
Camshaft oil seals
Put a new oil pressure switch in - if not now you'll be doing it under the car
Install a new engine mount, the one that bolts to the front of the engine
New trans and torque mounts are a good idea, but can be done later
This is a big one. Pull the head and have the valves/seats ground since there's 140K miles on it. I've seen to many burnt exhaust valve topics on here to mess around. You DON'T want to deal with this later. $300 more now and skip the headache.
With 140K there are alot of unknowns.
Old 14 Mar 2017, 01:53 pm
I am reading exactly what you posted...
If this is the correct wording then the complete long block needs to be rebuilt. This means all the machine work, new reciprocating parts, questionable parts like oil pump, if really for building up relating to performance than perhaps eliminating the complete balance shaft assembly and naturally a complete head rebuild and port work.
If what you meant was freshening up an engine with that many miles on it...well at least pull the head and have a valve job done.
Maybe some but not all of what was previously posted?
As that member said quote: "With 140K there are a lot of unknowns."
ptprice and chuzz like this.
Old 14 Mar 2017, 02:56 pm
Handy_Cruiser's Avatar
Camshaft oil seals
Great list!
How did you take the slack out of the balance shaft chain? Did you just shim the balance shaft assembly or did you pull the crank loose and replace the chain?
Old 14 Mar 2017, 03:21 pm
rob302's Avatar
handy here for the balance chain:
Old 14 Mar 2017, 03:31 pm
rob302's Avatar
i would recommend buying no less than two books similar to this one:
https://www.amazon.com/High-Performa.../dp/1613250061
and usually after reading two, one will be worth its weight in gold, and one will be fairly obviously written by someone just trying to sell books. i often refer to one for my ford that was written by a machinist and i've learned a ton from it.
Old 14 Mar 2017, 03:41 pm
Attachment 21132
Very cool. I didn't know you could adjust the tension. As I've said many times, Rob. I believe you are the smartest guy on this forum.
Of course, you do realize I'm still going to have to go a salvage yard, pull a cv shaft our of T350 and count the splines just because of what you said earlier.
Old 14 Mar 2017, 03:44 pm
rob302's Avatar
sweet.
Handy_Cruiser likes this.
Old 17 Mar 2017, 12:49 am
Do think instead of refurbishing the valves I could buy new ones and save money right?
Old 17 Mar 2017, 06:37 am
Even with new valves, the seats would need grinding and the valves would have to be lapped in, in order to be properly seated. I don't understand your logic on this one, if you're trying to save money.
Ignorance can be educated, crazy can be medicated, but there IS no cure for stupid.
'05 bought 3 weeks ago - engine light & won't start kmphx72 Tech & Performance Forum 2 30 May 2015 01:01 pm
Just Bought a PT Seaspark General PT Cruiser Discussions 10 16 Feb 2008 05:02 pm
Bought my new PT under 48 hrs ago chubsiewhubsie General PT Cruiser Discussions 19 13 Sep 2007 07:09 pm
Bought the bra gonzomania The Detail Shop 11 15 Jul 2004 07:31 pm
