DIFFERENT RADIATOR BRANDS & THICKNESSES
Like Tree3Likes
Old 17 Mar 2017, 11:11 am
Default DIFFERENT RADIATOR BRANDS & THICKNESSES
I have a 2002 non turbo pt cruiser . I am probably going to get another radiator but I can't accurately measure mine in the car . From what I can tell it is a wimpy 1" thick . Is there a thicker rad available?
Thanks in advance for any help.
Old 17 Mar 2017, 11:25 am
rob302's Avatar
Default Re: DIFFERENT RADIATOR BRANDS & THICKNESSES
I bought the $60 rock Auto radiator. I beat the piss out of the car and never had and trouble with overheating. Anything more expensive is just a waste of cash, IMO
Old 17 Mar 2017, 11:26 am
rob302's Avatar
TYC2298 is the one i got
Old 17 Mar 2017, 11:33 am
do you have ac?
do you have an auto trans?
is it 100 degrees where you live?
do you beat it with the ac on in 100 degree temp?
is this the TYC2298?
Thanks
Old 17 Mar 2017, 11:34 am
is it a direct replacement with no mods required?
does it fit a non turbo car?
Thanks
Old 17 Mar 2017, 11:57 am
rob302's Avatar
yes. mine was also a 2002
took 1 hour and 40 minutes to change out.
Old 17 Mar 2017, 12:37 pm
Handy_Cruiser did a great job at one time measuring the PT Cruiser radiators and I think a couple aftermarket ones or at least found the specification on the internet.
Now what I did is a comparison between a Turbo radiator and a NA for temperature control.
ZERO difference!!!!
Although I would get the Turbo applicated radiator for my GT Turbocharged PT Cruiser, from a cooling stand point if a PT Cruiser is NA upgrading to a Turbo Radiator will do absolutely nothing in the way of temperature control.
A suggestion ...paint the radiator semi or flat black. Some tests done with finned cooling radiators have shown at low speed vehicle operation of some increased cooling properties.
The PT Cruiser radiator ability to control heat is not about thickness but more about airflow!!
ptcruisersteve and chuzz like this.
Old 17 Mar 2017, 01:16 pm
I have the original 16 year old radiator, never had a problem (cept for the fan).
YES it's Auto Trans
Yes, I use A/C all the time
Yes, it gets to be 100 degrees sometimes. Above 90 most of the summer.
I do flush it every 3-4 years using 50/50 mix.
chuzz likes this.
Old 17 Mar 2017, 07:13 pm
rob302's Avatar
Haha yes I beat on it when it was 100 out, actually cranked, no issues. Mine has a manual trans, but that radiator works for either.
Old 17 Mar 2017, 07:28 pm
Airflow is a problem that the factory helped with by adding those black pads around the radiator/condenser unit held by plastic pins. These are often discarded by mechanics and owners doing maintenance work but they are necessary.
Air flow through the grille to the core and condenser must be blocked from escaping over under or around rather than THROUGH the coolers.
This problem is a curse of early hotrods where larger engines and small radiators meet and easily solved by thorough inspection to find the airpaths by passing the core faces. Once determined you can use duct tape to seal leaks between sheet metal panel joints.
Belts brands- my experience.. 03TXPTGT General PT Cruiser Discussions 5 31 Dec 2014 04:37 pm
O2 Sensors,,, Brands to Avoid? 08 Base Sarasmiles General PT Cruiser Discussions 17 07 Nov 2014 06:09 pm
overall audio brands. what should i do?! jon711 Sound and Security Forum 4 18 Jun 2010 08:04 pm
3m auto tape in various thicknesses? Curruzr General PT Cruiser Discussions 8 14 Mar 2006 05:57 pm
