Removing right engine mount
Old 17 Mar 2017, 02:29 pm
RVC RVC is offline
Default Removing right engine mount
The project has been on hold for a while and I'm finally able to get back to changing my timing belt. The engine is presently supported on jacked blocks and up quite a way, both belt covers are removed as are the bolts that hold the mount.
The engine mount comes out of its hole in the frame but not quite far enough to remove it. How high do I have to take the engine before I can get the mount out? Or can the engine/trans me moved to the left?
I will appreciate any help. Thanks.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Last edited by RVC; 17 Mar 2017 at 05:31 pm. Reason: I would like to delete this post. Thanks. RVC
Old 17 Mar 2017, 04:12 pm
Default Re: Removing right engine mount
RVC
Really you asked this?
... um..... you carefully raise the engine and transmission watching out for all the lines and hoses etc not to harm them, until you can remove the mount!
duh!
removing the accursed engine support bracket & broken bolt on engine mount ushumgal General PT Cruiser Discussions 6 11 Dec 2015 04:47 am
Lower Engine Mount Leroy Feedback and Support 10 17 Jul 2014 02:12 pm
Top Engine Mount! mdfrodolives Tech & Performance Forum 6 18 Apr 2011 08:04 pm
ok how do you get the top right engine mount out??? llcelebrity Tech & Performance Forum 6 20 Feb 2009 11:44 am
Engine Mount Problems chris1916 Tech & Performance Forum 1 15 Jan 2009 03:19 pm
