RADIATOR FAN CONNECTOR WON'T DISCONNECT
Like Tree7Likes
  • 1 Post By soyomb
  • 1 Post By 03PTCrewser
  • 1 Post By barnett468
  • 3 Post By NitroPT
  • 1 Post By rsrocket1
Old 17 Mar 2017, 09:08 pm
Default RADIATOR FAN CONNECTOR WON'T DISCONNECT
What is the deal with this pos . I push the tab to raise the clip and it will not disconnect?
What is the red thing?
Thanks
Old 17 Mar 2017, 11:17 pm
Default Re: RADIATOR FAN CONNECTOR WON'T DISCONNECT
If I remember correctly, slip a small screwdriver into the closed end of the red thingy and move it away (to the right in the picture). Then you should be able to uncouple the plug.
03PTCrewser likes this.
2016 Kia Soul Plus Black
Old 17 Mar 2017, 11:45 pm
Like soyomb has said, that red piece is the lcok, has to be disengaged before you can get both connectors pryed apart.
Old 18 Mar 2017, 02:41 am
ok, one end was an open loop which is now broken . i do not want to break this plug so please tell me exactly which way the red thing has to move.
do i remove the red thing completely?
thanks
Old 18 Mar 2017, 02:57 am
Using your pic as a reference slide the red piece to the right. It moves between 1/16th and 1/8th of an inch (not much). It doesn't need to be removed completely. That will unlock the connector and allow you to separate it.
CREWZIN likes this.
Old 18 Mar 2017, 10:53 am
xlnt thanks . i already tried that and it wouldn't move but that was after i tried to pull the plug apart so there might be tension on it . i will push the plug back together then try it and will post the results.
only been working on cars for 40 years and still can't disconnect a "simple" plug, lol.
Old 18 Mar 2017, 01:08 pm
got the plug disconnected . that was unpleasant . putting dielectric grease on it for reassembly.
thanks for the info.
chuzz likes this.
Old 18 Mar 2017, 02:21 pm
Use WD 40 or better to use electrical parts cleaner on dirty connectors before attempting working on them if possible.
Be patient with them they will come apart without any force. The last thing you want to do is break the connector or the locking tab.
FYI for those that frequent auto wrecking yards. I use to clip off at the wires about 2-3 inches from the connector as many different type of locking connects to have in the shop/garage for the occasional replacement of broken ones and also for electrical projects.
Fk5, ptcruisersteve and chuzz like this.
Old 20 Mar 2017, 11:10 am
rsrocket1's Avatar
Barnett468,
Better get used to those locking clips. They are everywhere on the PT Cruiser. The good thing is that once you know how they work, it's a piece of cake to remove the connectors and reinstall them without forcing or breaking anything.
LionPT likes this.
What is this connector in-between the radiator & front bumper for? ingram87 General PT Cruiser Discussions 8 16 Jan 2015 10:33 pm
Picture of radiator fan assembly 4 wire connector a417latino General Turbo Discussions 12 22 Jul 2014 08:22 am
Radiator/Cooling Fan Check & Connector Fix alexptla General PT Cruiser Discussions 4 01 Nov 2011 05:59 pm
Fan Relays - How Do You Disconnect Them? AlphaBob Tech & Performance Forum 5 09 May 2011 01:43 pm
