Oil Pressure
Old 27 Jun 2004, 12:59 pm
Default Oil Pressure
After having it just sitting in the pod for allmost a year,,,, finally got my oil pressure gauge hooked up, 70psi cold idle
Tom
Old 28 Jun 2004, 04:54 pm
quote:Originally posted by Thier
After having it just sitting in the pod for allmost a year, finally got my oil pressure gauge hooked up, 70psi cold idle
Tom
Is this electrical or mechanical? I have a guage that I need to hook-up also, however I need a sender (electric) to make it happen.
What type of oil are you using, and what's the figure when at hot idle?
Old 28 Jun 2004, 06:16 pm
I use an electical oil pressure because I don't want oil inside of car, boost is mechanical. 5w-30 Mobile one, when it warmed up it dropped to 25-30psi, which is a little better. When you go to install yours, take out airbox, and look for 2 plugs under the cams, they are a odd size, about 3/16", I got a screw extractor which had a square drive that was the perfect size, and used that to remove plug.
Tom
p1188 Chipmunk Turbo Performance 29 02 Mar 2009 09:59 pm
Oil pressure sending unit littleblueGT Turbo Performance 3 27 Oct 2004 02:44 pm
Blow Off Valve Conversion Kit gonzomania Tech & Performance Forum 10 08 Sep 2004 09:08 am
boost pressure runnung mbc pt pete General Turbo Discussions 4 12 Jun 2004 07:02 am
15" tire pressure? Brad Vandrasik Wheels, Tires, Suspension 6 03 Dec 2003 11:22 am
