P0401 code keeps coming back but no pending code
Like Tree3Likes
  • 3 Post By 96realwe
Old 22 Mar 2017, 05:49 pm
Default P0401 code keeps coming back but no pending code
Hi
The car is a 2002 pt non turbo touring 110k I just had the head surfaced then replaced head gasket,timing belt and components, water pump and a cracked exhaust manifold with Dorman oem replacement. After it overheated on my girl friend and she kept driving {thermostat stuck}. No issues with the repair which I did myself but since then about once a week it throws the egr valve code P0401 I would normally just replace the egr valve but it was not bad before she overheated the car and there are no pending codes after it throws the P0401 anyone have recommendation or comment.
Thanks
96realwe
Old 22 Mar 2017, 09:18 pm
Handy_Cruiser's Avatar
Default Re: P0401 code keeps coming back but no pending code
On a PT Cruiser, insufficient EGR flow is detected by the MAP sensor. The PCM expects a pressure change sensed by the MAP sensor when the EGR valve is actuated. If there is not enough of a pressure change, it can throw the P0401 code.
If me, I would remove the MAP sensor and clean it. Chances are it's not bad, only dirty. I've seen engines with blown head gaskets that sometime blow bunt coolant back into the intake manifold. Yours may need a thorough flush and cleaning. I'd also look for any potential vacuum leaks and make sure the vacuum lines and electrical plug is an good shape on the EGR system.
It should be noted that I am a Safety Engineer among other things and I haven't worked as a professional mechanic since I was young strapping lad with long sexy flowing hair before college. And even then, I mainly worked on big trucks and heavy equipment. Nowadays, I enjoy working on these funny looking little cars for fun and relaxation.
Old 23 Mar 2017, 08:33 am
rob302's Avatar
..dp.
Old 23 Mar 2017, 08:39 am
rob302's Avatar
More than likely you attached the EGR valve right, but there's three vacuum lines on the EGR transducer. You may have mixed up the two that go on the same side, or more likely you just forgot to reattach the electrical connector.
Old 23 Mar 2017, 08:41 am
a P0401 is a universal code for misfire in cylinder 1, not an EGR code. Double check what code number you are getting.
Edit: Nope nvm im dumb
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 23 Mar 2017, 08:49 am
rob302's Avatar
0401 is egr flow. Your thinking 301
Old 23 Mar 2017, 08:50 am
whoops my bad, I was thinking of 301... ooops.
Old 27 Mar 2017, 01:38 am
Thanks everybody I have not had time to redo it lots of work right will revisit her car problems mid week
Old 30 Mar 2017, 10:01 pm
Problem solved forgot to hook up the vacuum hose on EGR hooked one on each side but missed the one on inside of the egr with 2 connnections thanks rob302
rckstein, rob302 and JDK52 like this.
Malfunction Indicator with P0401 code Patrick_Dickey Tech & Performance Forum 17 26 Feb 2018 04:05 pm
2001 PT cruiser code P0401 whirlinwilly Tech & Performance Forum 1 21 Apr 2014 03:42 pm
P0420 code Converter Code? 2008/110,000 miles Sarasmiles Tech & Performance Forum 8 28 Mar 2014 07:08 pm
code P0401 jmrcmama Tech & Performance Forum 2 12 Apr 2010 05:42 pm
0344 Code-Sensor Changed and now back Cajunsim Tech & Performance Forum 1 19 Nov 2008 07:17 pm
