2005 pt with lots of codes
Like Tree3Likes
Old 22 Mar 2017, 07:13 pm
Default 2005 pt with lots of codes
After doing a timing belt, I started the car and runs very rough. It has thrown 5 codes, P2074 MAP/MAF circuit high, P0113 Intake air temp sensor 1 circuit high, P0118 Engine coolant temp sensor 1 circuit high, P0108 MAP barometric pressure circuit high, P0123 Throttle position sensor switch A circuit high. Does this mean anything to anyone? Major vacuum leak? Any help will be greatly appreciated. Its a 2005 limited non turbo, automatic.
Old 22 Mar 2017, 07:30 pm
rckstein's Avatar
Default Re: 2005 pt with lots of codes
Welcome to the forum
Old 22 Mar 2017, 07:35 pm
Thanks, I had a whole thing typed out then my computer erased the whole thing and I wasn't retyping the whole thing.
But, it seems as though all the codes are related. And Its flooding the engine with gas.
Old 22 Mar 2017, 07:36 pm
VsandFords's Avatar
Welcome to the forum.
Was it running smooth without codes before the timing belt change?
Old 22 Mar 2017, 07:40 pm
I'm not sure, I bought with a bad head gasket. Previous owner says it ran fine but he was trying to sell it too.
I looked at all the connections for maybe a bad wire. Nothing. Its definitely getting to much fuel. I'm sure due to the codes.
Old 22 Mar 2017, 09:35 pm
My 1st thought is you have a couple connectors that aren't on. Some are hard to see on the backside
Old 22 Mar 2017, 09:56 pm
I would suggest checking to see if you have the ignition coil connector switched with the camshaft position sensor. This happens sometimes when taking the engine apart and putting it back together.
Old 22 Mar 2017, 10:04 pm
I thought that too, would it run if swapped? I'm not getting a camshaft sensor code.
Old 22 Mar 2017, 11:22 pm
If you are not going to check to see if the two wires are switched just check the voltage on the ones you are getting a code on the sensor and post what the voltage actually is. You might be getting a different source voltage from somewhere else.
Old 23 Mar 2017, 06:21 am
I'll check the plugs this morning. I'll also check the voltage going to the plugs. Do you happen to know the color of the wires going to the cam sensor?
2005 pt error codes nvhunter Tech & Performance Forum 4 21 Aug 2015 04:23 pm
2005 Crusier 4 codes any ideas Jbird Tech & Performance Forum 7 04 Jul 2015 12:14 pm
Help! Error codes...lots going on! denab General PT Cruiser Discussions 25 31 Jan 2015 07:17 pm
2005 PPT Cruiser Still Stumbles after lots of work done. qcruiser Tech & Performance Forum 8 12 Jul 2011 08:56 pm
2005 pt overheat no engine codes bettyblup Tech & Performance Forum 5 21 May 2008 02:06 pm
