Flashing CEL p0138 help
Old 23 Mar 2017, 11:33 am
Default Flashing CEL p0138 help
So I have a 2004 PT Cruiser GT 2.4 Turbo 108xxx
It has been idling roughly for a while, which I contributed to cold starts. Then the CEL came on with p0138, po172, po301 and po504. I changed plugs/wires, intake manifold gasket, both o2 sensors and the oil pressure safety sensor and even the gas cap. I put everything back together and the car seemed fine for 2 days and then the CEL lit up and started flashing and went away which is never a good sign. Back to rough drivability and intermittent flashing CEL. Have only been able to pull a po138 code which is for the downstream o2, which I have replaced. So now I'm stumped. Idle stays around 750 on start up and 800 at idle stop. Could this be a failed Cat or head gasket or something else that's gonna give me a giant headache or something as easy as dumping fuel injector cleaner in my tank or maybe the timing is off? I searched the forums and have found bits and pieces related to my issue but nothing this specific. If anyone has a any suggestions or ideas, it would be much appreciated!
Tags
2004 turbo, p0138, rough idle
Code P0138? PrincessBubblegum General PT Cruiser Discussions 4 08 Apr 2015 08:02 am
06- P0138 & P0303 PrettyTallCruiser06 Tech & Performance Forum 8 05 May 2013 03:39 am
P0138 Code but where? niel General Turbo Discussions 1 11 Feb 2012 03:57 am
Codes P0138 and P2097 bob2006 Tech & Performance Forum 2 21 Oct 2010 04:33 pm
P0138 Fault irishman331 Tech & Performance Forum 19 01 Aug 2009 11:14 pm
