Turbo owners question
Like Tree3Likes
  • 1 Post By Busted_PT
  • 1 Post By Imakenocents
  • 1 Post By rckstein
Old 25 Mar 2017, 03:17 pm
Wink Turbo owners question
2004 GT Turbo.jpgI just purchased a 2004 Gt ( see attached picture ) that I bought sight unseen other than the pictures. I was told by the owner that she believed it had a blown head gasket, and it very well may have a blown head gasket. My question is related to the turbo charger. I have not worked on one of these Pt's that is turbo charged to this point. I have have had this car at home now a few days and today I finally raised the hood and looked around for the obvious signs of trouble. The oil is full and relatively clean with no signs of coolant in the crankcase but the radiator coolant level is down and is milky and obviously mixed with oil. The car will start easily and has no detectable misfire, seems smooth, and is not smoking out the exhaust in the minute or so I ran it. Now for the question, Is it possible the coolant and oil are coming together at the turbo charger through an oil seal leak within the turbo and not through the cylinder head or gasket? I plan to tear it down anyway with current mileage at 93,500, and change the timing belt and related components in the belt area and while I'm in there I'm going to replace the head gasket anyway since not much more work is required to removed the head, as I've done with the others I have repaired. I'm quite uneducated on these turbos but I do know they receive oil and coolant circulation no doubt for the bearings in the turbo. Just wanted to see what you experienced turbo owners thought of those initial indications.
Old 25 Mar 2017, 03:55 pm
Default Re: Turbo owners question
The oil cooler between the filter and block have Ben known to leak into the oil. Being low on coolant could be any of the usual suspects. If no sweet smell to exahast i would look at the other causes of transfer. Turbo itself is not likely.
Imakenocents likes this.
Old 25 Mar 2017, 06:25 pm
Wink Re: Turbo owners question
Thank You, Busted, based on my current observations I do believe I have a dual issue going on but I think a better outcome than what I had initially anticipated.
1) I think the oil cooler is the culprit for the oil being mixed in with the coolant in the radiator, right now I do not suspect the head gasket is blown. If necessary I will do further testing in that regard.
2) After getting a good look at the bottom of the car it does appear the water pump has been leaking, which, as you know, is a common failure on these cars.
I have ordered a new oil cooler and I'm going to change the timing belt and related components in that area while in there. Thanks for the assistance!
Busted_PT likes this.
Old 25 Mar 2017, 06:37 pm
rckstein's Avatar
It's a beautiful PT, hope you get it running without having to put too much $ into it
Question for 06-10 PT Owners with HID Headlights Vengence General PT Cruiser Discussions 0 20 Jan 2017 12:04 pm
Question for owners of older PT rolm General PT Cruiser Discussions 13 28 Oct 2015 02:06 pm
Greetings! (and the Big Question for PT owners...) greeley Welcome New PT Cruiser Members 8 06 Sep 2013 07:26 pm
Question to '06 - '10 First Time Owners Chromenut General PT Cruiser Discussions 8 25 May 2013 12:18 pm
General Question for all PT Convirtable owners bucksfan1976 PT Cruiser Convertible Forum 1 31 Aug 2010 04:04 pm
