Transmission issue??
Old 27 Mar 2017, 11:16 am
Default Transmission issue??
04 turbo PT Auto
first off I noticed that when I slowed down to like 10mph and got back on the gas I would hear a slight thunk sound? and I could feel it jerk a bit..
driving it was fine and it shifted fine no issues..
was driving it today and at 55mph the RPMs suddenly jumped up?? so I pulled over and put it in park to see if it would pull out and shift through all the gears.
whne I put it in gear and tryed to pull out it made a chunking sound? and would hardly pull out? it moved about 50yards very slow,I stopped again and the it would not move at all in gear?
anyone ever have this? Could it just be the axil stripped? or I pray not the trans..could that happen?
just got it home and gonna look at it today..now I got 2 PTs setting that wont run lol..
Old 27 Mar 2017, 12:51 pm
Default Re: Transmission issue??
I would check the miter mounts. Especially the middle one. This will creat slack in the drive line. Your thunk.
Old 27 Mar 2017, 12:58 pm
At first when you said thunk, I was thunking lower control arm bushings. But with it not moving, I have to agree with Danny. It sounds more like your motor has shifted. A LOT! Check that lower engine strut mount too. Maybe the rubber has broken out of it completely.
Ignorance can be educated, crazy can be medicated, but there IS no cure for stupid.
Old 27 Mar 2017, 01:07 pm
That's not gonna keep it from pulling.or not move at all
Old 27 Mar 2017, 01:15 pm
Fk5 Fk5 is offline
Did you check the fluid? That is always step #1 with an auto in my experience. With the old torqueflites when the are low in fluid it would take revs to build pressure and they could make a thumping sound when the finally engage. Thankfully, I try to be a 4 (later 5, now 6) speed man.
2003 GT 5 speed
162,000 miles
Old 27 Mar 2017, 01:49 pm
Yes fluid was fine..are the turbos different transmission s than regular PTs?
Old 27 Mar 2017, 02:26 pm
My turbo is an autostick. I THINK they put that in the non turbos too. I'm thinking they all have the 41TE transmissions, but I'm NOT a mechanic. And if your motor mounts are busted, the engine can shift far enough to pull a half shaft out of the transmission. I would think that if that happened though, you'd have a leak. IDK, just guessing.
Old 27 Mar 2017, 02:28 pm
thanks no leeks n mounts are fine...
Transmission Issue...I think. Hoosier General PT Cruiser Discussions 1 04 Dec 2015 07:31 am
Transmission Issue countryboy Tech & Performance Forum 1 24 May 2015 08:47 pm
What a day! Transmission issue? Jimmy2011 Tech & Performance Forum 8 13 May 2015 09:12 pm
transmission issue?? mdskinner731 General PT Cruiser Discussions 8 18 Mar 2013 03:19 am
Transmission issue... MDCruiser Tech & Performance Forum 10 06 Mar 2006 08:14 pm
