Is my water pump causing a coolant leak
Like Tree17Likes
Old 27 Mar 2017, 07:57 pm
Default Is my water pump causing a coolant leak
Our 2002 with 70k miles has started leaking coolant rather heavily. (note the car had a coolant flush to switch to green before i bought it - 25k ago). The upper and lower thermostat housings seem to remain dry from all angles I was able to view them. The highest place I can see water is the bottom bolt of the water pump.
One other notable is that the water will continue to leak with the car off and the fluid level in the rad is still full ... guessing it's just leaking the fluid out of the block (which seemingly should eliminate anything above the thermostat?).
Anyone other areas I should check that would be above the water pump or any other insight before I commit to the timing belt/water pump project?
I didn't see many other threads about failed water pump gaskets. I'm guessing this isn't too common? (it's possible the prior owner did the timing belt 25k ago and the pump/gasket are aftermarket. Sadly, no records available).
Some images are attached. I got a clear view of the upper housing so i'm confident that's ok. I can only see the top half of the lower housing .. it looks dry, but it could be possible that it's leaking out of the lower side of it where it bolts to the head. Even with the wheel well cover removed I still couldn't get a look at it. It looks like i'll have to start disassembly to truly inspect it.
Here's a video I took. It does a great job of showing how fast the leak is. You can see also see how the bottom water pump bolt is involved in the water flow. (i kept trying to fix the focus, but my phone did not obey).
Old 27 Mar 2017, 08:15 pm
rckstein's Avatar
Default Re: Water pump? coolant leak
BTarb24 likes this.
Last edited by rckstein; 04 May 2017 at 11:10 am. Reason: Removed-because some other member wants to control the forum
Old 27 Mar 2017, 08:29 pm
Originally Posted by rckstein View Post
I noticed in your video that it appears like one of the webs in the lower torque strut is torn, should be replaced soon.
Nice eye! It definitely looks like you're right. Thanks for the catch
rckstein likes this.
Old 27 Mar 2017, 08:33 pm
rckstein's Avatar
Old 27 Mar 2017, 08:43 pm
I just had the struts replaced on my PT and the same web was torn on mine, the upper was also torn. They both had the same number of miles on them as they had been installed at the same time.
It looks like the opposing web on the lower has some nice dry rot and is about to fail too. I'll try to spy the upper tomorrow. If i can't see it then i'll just assume it's also bad.
Here's a pic of the bad lower with dry rot. I also pointed at the lower bolt of the water pump. You can kind of see how the right side of the pump is dry.. leading to the leak either being right at the bolt or somewhere to the left of it (or above it)
EDIT: hmm.. looks like the forum reduces the resolution significantly. Here's a higher res version: http://i.imgur.com/CrKE2BH.jpg
Old 27 Mar 2017, 09:04 pm
rckstein's Avatar
BTarb24 likes this.
Last edited by rckstein; 04 May 2017 at 11:11 am. Reason: Removed-because some other member wants to control the forum
Old 27 Mar 2017, 09:26 pm
On mine, on the upper, it was the front web that was torn:
You likely won't be able to see it because it will be blocked by the bracket
Thanks, I'll just add the upper to the order then.
Anyone have any experience with a leaking water pump?
Old 27 Mar 2017, 10:03 pm
Hmm, Sorry for anyone that reads this and is confused about what the topic is. I edited my original post to include thumbnailed images and the entire post just up and vanished. I assume it'll be restored when a mod comes online - though, the thread sure wont make much sense for interim vistors
relevant support post: OP post gone?
Old 27 Mar 2017, 10:05 pm
rckstein's Avatar
Old 28 Mar 2017, 07:57 am
rob302's Avatar
That's how mine was when it was leaking. Nothing left to do but change it. Takes about 7 hours.
BTarb24 likes this.
Water pump? coolant leak rckstein Tech & Performance Forum 7 27 Mar 2017 10:05 pm
Coolant leak between water pump and bottom radiator house Morgan89 General PT Cruiser Discussions 0 12 Oct 2015 01:38 pm
Where to take car for Timing Belt/Water Pump/Transmission Flush/Engine Coolant flush funkyfred General PT Cruiser Discussions 0 14 Sep 2015 01:41 pm
Coolant Leak, Is it my Water Pump? falconut Tech & Performance Forum 17 06 Feb 2013 04:14 pm
Possibly water pump leak mrwag Tech & Performance Forum 17 23 Oct 2010 03:26 pm
