Grenade style timing belt tensioner
  • 1 Post By Imakenocents
Old 29 Mar 2017, 03:34 pm
RVC RVC is offline
Default Grenade style timing belt tensioner
I have recently installed this tensioner. The 01-04 pdf service manual downloaded from this site has a drawing (Fig. 171) that shows a tensioner with setting notch and spring tang that my tensioner or engine block do not have. I did notice that when "the pin" was pulled the tensioner presses firmly against the belt. Is this all that needs to be done, or do I need to search for some missing parts under my car?
Thank you!
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 29 Mar 2017, 03:57 pm
rob302's Avatar
Default Re: Grenade style timing belt tensioner
i found the old style tensioner on alldata, but all it lists is how to remove the old style one, and says to see "updated tensioner info"
Old 29 Mar 2017, 04:50 pm
Wink Re: Grenade style timing belt tensioner
The tensioner on the 2002 is the older design and does not have the tang as you describe. The old version is fine and can still be purchased through a multitude of parts suppliers. Once the original style tensioner has been mounted in place and the belt installed correctly then it is just a matter of pulling the pin and then rechecking your timing alignment manually rotating the engine through 720 degrees of crankshaft rotation or two complete crankshaft revolutions and verifying your timing alignment.
CREWZIN likes this.
Old 29 Mar 2017, 07:51 pm
RVC RVC is offline
Sounds good to me! Thanks very much.
RVC
Manual timing belt tensioner vs auto belt tensioner Bandit2014 Tech & Performance Forum 9 11 May 2016 01:57 pm
Timing Belt Tensioner Help GriffinW Tech & Performance Forum 0 10 Aug 2015 08:35 pm
New Style Timing Belt Covers on '02 2.4? itcousin Tech & Performance Forum 0 18 Jun 2012 10:11 am
Is this the new style timing belt cover? JenneK Tech & Performance Forum 14 11 Jun 2012 01:56 pm
What mod for the timing belt cover for new style tensioner? clark6 Tech & Performance Forum 16 25 Oct 2010 07:05 pm
