P0016 FIXED !!!!!
Like Tree3Likes
  • 3 Post By 2_cruisers
Old 29 Mar 2017, 06:26 pm
Default P0016 FIXED !!!!!
i had my friend that owns the local dodge dealership flash the computer in the 05 GT and the P0016 code is gone. he told me when you change the crank and cam sensor you need to flash the PCM so it relearns the car. i also added a MSD coil, new MSD wires, K&N typhoon intake. along with the timing belt, tensioners and water pump. transmission coil pack. so i guess the computer was confused. all fixed for only $25.00
i just thought i would post the outcome of the repair.
thanks.
Old 29 Mar 2017, 06:40 pm
rckstein's Avatar
Default Re: P0016 FIXED !!!!!
Glad to hear that you're back on the road, and for a very reasonable price!
Flashing the PCM is one of the same remedies from this tech:
Chrysler PT Cruiser i have a trouble code p0016, Replaced
Old 29 Mar 2017, 06:48 pm
I would suggest putting or leaving the original sensors on the engine when replacing the timing belt. Otherwise you have more room for problems to come up.
P0016 ? bad PCM ?? 2_cruisers Tech & Performance Forum 9 19 Mar 2017 05:45 pm
P0016 hfd General PT Cruiser Discussions 5 29 Dec 2016 12:12 am
No Cruise and P0016 altaylor Tech & Performance Forum 5 15 May 2013 05:46 am
P0016 sleepy General Turbo Discussions 0 01 Mar 2013 03:30 pm
p0016 code guss Welcome New PT Cruiser Members 2 18 Feb 2012 05:09 pm
