How bad is my frame damage
Old 30 Mar 2017, 07:28 pm
Default How bad is my frame damage
'08 hit in the front, impact from the side and tweaked the front pretty good. In process; stripping mode, just wondered how I could have frame damage estimated from pics or some way short of putting it on a wrecker to a high dollar shop. Also what causes oil to be at the bottom of the spark plug "wells"? Turns over and tries but won't start. Few puffs of exhaust smoke out the tail pipe as it's rolling over. Has fuel to rail, but didn't check psi, and has spark. 140,000. Really like this car as a first timer and am going to try and get the salvage title turned around. Thanks for your wealth of info.
Last edited by alfa244romeo; 30 Mar 2017 at 08:30 pm. Reason: Added another problem I remembered.
Old 30 Mar 2017, 07:48 pm
rob302's Avatar
Default Re: How bad is my frame damage
where's the pics?!?
Old 30 Mar 2017, 09:01 pm
rckstein's Avatar
Welcome to the forum
Is this a PT that you don't own yet, but are looking at buying and it has a salvage title?
It better be real cheap, or I would pass, there are a lot of other PT's out there in better condition, just needing a little TLC.
Old 31 Mar 2017, 08:10 am
If you can strip down to the frame and ensure it is lined up, you could put the whole thing in an oven to re heat it and destress the metal. But that's gonna be more expensive than any PT is worth.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Help! Bent Frame gt4431b General PT Cruiser Discussions 18 29 Jan 2017 11:50 pm
Unibody/Frame Damage? Punkshoo General PT Cruiser Discussions 14 29 Apr 2012 10:56 am
Convertible Frame - Where? HotRodMomma Southeast PT Forum 4 01 Mar 2010 04:43 pm
Sub-frame corrosion koolsville General PT Cruiser Discussions 12 12 Aug 2009 06:22 am
LED Plate Frame satellite66 Exterior Accessories Forum 10 30 Oct 2003 04:55 pm
