Thrust Bearing Dimensions
Old 09 Apr 2017, 09:02 pm
Default Thrust Bearing Dimensions
My 2006 PT Cruiser automatic trans 2.4 non-turbo crankshaft walks and pushes out the crankshaft seal. I took the engine apart to replace the thrust bearings. The upper TB fits, but the lower new one does not fit. The locator tab is 2mm off. I tried two separate bearing sets with the same results. Where can I find the specs for the lower crankshaft cap to see if the locator tab slot is properly machined?
Thank you
Old 09 Apr 2017, 09:16 pm
rckstein's Avatar
Default Re: Thrust Bearing Dimensions
Welcome to the forum
This is a known issue with a certain batch of the Gen2 PT's. Supposedly my PT falls within that batch, but mine has not experienced any issue, to date. From reading several other threads in this forum, it appears the problem occurs more on cars with a manual transmission.
Are you the original owner? If so, since it is a known issue with Chrysler, some members, in other threads, had reported that their issue was fixed under the powertrain warranty. The fix is that the block has to be replaced. However, if you are not the original owner, and you have already torn down the engine, you probably won't be able to get any relief from Chrysler.
Another 2007 failed engine: oil streaming - bad crankshaft thrust bearing
Please go to the Welcome New PT Cruiser Members section and introduce yourself and your PT.
Old 09 Apr 2017, 09:45 pm
Thanks. I am not the original owner. There is a salvage yard with several of them. Perhaps I can take one of those?
Old 09 Apr 2017, 10:03 pm
I wonder if it would be safe to grind off the locator tab from the new lower thrust bearing?
Old 09 Apr 2017, 10:39 pm
rckstein's Avatar
How many miles are on the vehicle? Did you buy it from the original owner, or from a lot? Was that the only issue that it had? Is the rest of the vehicle in good condition?
If you got it from the original owner and that was the only issue, too bad the original owner didn't get it fixed under the powertrain warranty.
Just curious, what is the date of manufacture of your PT? It will be listed on the VIN label on the drivers door, on the top line: DATE OF MFR
Old 10 Apr 2017, 06:47 am
could you use a lower bearing cap from another year that matches
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 10 Apr 2017, 09:04 am
111,000 miles. That is the only issue I know of. I am the third owner. The previous owner said it started when he got it. 6/2005
Old 10 Apr 2017, 09:06 am
I probably could, but the problem is that batch of years could have the same issues. That's a lot of time in the salvage yard. But, I may have to resort to that.
Old 10 Apr 2017, 10:02 am
rckstein's Avatar
The other issue you have is, whatever motor you get, you should plan on replacing: timing belt, water pump, tensioner, idler pulley, cam seals, crank seal, center motor mount including new bolt.
Yours was an earlier build, my PT was made 10/05, so hopefully they fixed the problem by then, but I have not been able to find any accurate info on what batch had the bearing problem.
Old 10 Apr 2017, 10:36 am
rob302's Avatar
can you post a picture of the tab that's 2mm off?
i wouldn't use a bedplate from another block without having a machinist check and possibly line hone it. is that ok to just switch these from block to block?? asking, as i don't know.
Tags
crankshaft, thrust bearing
Turbo Ball bearing / Journal bearing Pippov Turbo Performance 3 25 Sep 2016 08:12 am
Hatch Dimensions? bgowdy General PT Cruiser Discussions 3 11 Jan 2016 06:50 pm
Air bag dimensions DieselPunk Wheels, Tires, Suspension 0 26 Mar 2015 06:28 pm
Another 2007 failed engine: oil streaming - bad crankshaft thrust bearing Geogee1 Tech & Performance Forum 53 20 Oct 2014 08:51 pm
Crank Thrust Bearing leakypt Tech & Performance Forum 2 10 Feb 2012 09:38 pm
