TCM Location
  • 1 Post By Dahoopd
Old 16 Apr 2017, 05:38 pm
Default TCM Location
Hello, I am trying to locate the TCM. The manual states its on the left frame rail forward of the suspension. Unless it fell of, I cant see it. Thanks for the help.
2003 PT Cruiser GT - Hand Me Down from Dear Old Dad / Mods: Lowered - Gauges (Boost, Oil Pressure, Volt, EGT, A/F
Old 16 Apr 2017, 06:07 pm
Default Re: TCM Location
The separate/remote SBC style TCM was used on the first two years (2001, 2002) only. You have a 2003 PT. It was the first year for the NGC control unit. It was used til 2006 when CanBus/TIPM took over.
Your TCM is contained in the PCM.
Jerry
Old 16 Apr 2017, 07:17 pm
Originally Posted by wwpptc View Post
The separate/remote SBC style TCM was used on the first two years (2001, 2002) only. You have a 2003 PT. It was the first year for the NGC control unit. It was used til 2006 when CanBus took over.
Jerry
I bought the stage 1 PCM upgrade. Does that mean by having the PCM programmed and installing it I will be replacing the TCM at the same time? Thanks for the reply. This car is pissing me off.
Old 16 Apr 2017, 07:29 pm
Yup, when you install the S1, you will be replacing the TCM at the same time.
Old 16 Apr 2017, 07:52 pm
Yepper!
Jerry
Old 17 Apr 2017, 01:01 am
_PTGT03's Avatar
Jerry
ever since the PT cruiser came out, the engineers had designed them with the CANBUS systems.
Old 17 Apr 2017, 04:26 pm
You Guys Rock! Thank you!
rckstein likes this.
Old 17 Apr 2017, 04:44 pm
But they didn't actually implement the CANBUS until the 2006 model year makeover.
Old 18 Apr 2017, 08:12 am
The TCM, or Transmission control Module.
Yes it is within the PCM, The 41TE, was one of the first electronically shifted automotive transmissions built by Chrysler, and one of the most technically advanced for it's time. It has a solenoid pack attached to the side of the transmission that is electronically controlled by the PCM.
This is why when you see PCM's for the PT, you see them listed as Auto or Manual. Auto PCMs will have the transmission control circuits enabled within.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
ECM location captpfd Tech & Performance Forum 5 23 May 2014 10:15 pm
Location for Fog lt fuse on 06? WeeHooker General PT Cruiser Discussions 3 14 Oct 2012 05:52 pm
PCM/ECU Location dsmturbo Tech & Performance Forum 2 09 Dec 2011 11:11 pm
PCV location discovering06 Tech & Performance Forum 9 22 Jul 2010 01:12 pm
Tee Location Mean Green Turbo Performance 6 07 Jan 2004 01:41 am
