20MPH at 4000RPMS
Like Tree9Likes
Old 19 Apr 2017, 02:39 pm
Question 20MPH at 4000RPMS
Good Afternoon Everyone ,
So today I was driving and felt a little buckle, and just continued to drive home.
An hour ago I took the PT out again, and while getting it going down the street, the RPMS wouldn't shift back, and I was driving 20MPH at 4000 RPMS.
Prior, I always wanted to floor it, but I could feel that I shouldn't. I would slowly push down until I got to 20MPH,30,40 and so on. Today It didn't even give me that option.
A quick google search brought up another vehichle and suggested transmition.
I have already replaced the coils,sparks,MAP sensor, Cleaned AIT, Oil 10/20,Filters etc. No codes after the reset of teh MAPs Sensor.
What are the possibilities?
Jim
Old 19 Apr 2017, 02:44 pm
Default Re: 20MPH at 4000RPMS
Check using a Diagnostic scanning tool for DTC (Diagnostic Trouble Codes) at the Diagnostic connector.(CANbus)
Check your fluid level of the transmission.
hahah Check your "FONT" size responding here on the forum!
2007ptc likes this.
Old 19 Apr 2017, 02:46 pm
rob302's Avatar
i would have floored it to see if it panic-shifted. like a cat that won't swim unless thrown in a lake.. ..serious
2007ptc likes this.
Old 19 Apr 2017, 02:48 pm
Originally Posted by rob302 View Post
i would have floored it to see if it panic-shifted. like a cat that won't swim unless thrown in a lake.. ..seriously
Yes but some members may have a hole in a small vacuum hose and do an emergency engine shut down thinking that the engine somehow went WOT without the TB actaully being fully or even less than 1/2 opened.
Originally Posted by members name withheld
I had just left and office and was about 500 feet down the road when suddenly the engine went full throttle and the brake peddle went all the way to the floor. Luckily (or "sadly" depending on how you look at it), this is not the first or even second time I had a car go inexplicably full throttle while driving down the road. So I just instinctively grabbed the key and turned the engine off.
LionPT and 2007ptc like this.
Old 19 Apr 2017, 02:58 pm
rob302's Avatar
aaah i get it. you're reading this like the idle won't drop, i'm reading it like the car wont shift out of first...
2007ptc likes this.
Old 19 Apr 2017, 03:00 pm
Smile Re: 20MPH at 4000RPMS
LMAO!!!!
Now I can't get the visual of a cat swimming in water. lol
I use the fonts because I was part of a Senior Citizen forum back in the day. lol
The Engine is hot and the fluid stick is at the HOT mark.
I'm watching videos now.
Rookie Question : I have 0 codes to use a Diagnotic Tool :
Thanks for all the quick responses.
Old 19 Apr 2017, 03:05 pm
Yes. It is a Automatic as well. It would only go past/below 4000 and drive "SOME WHAT NORMAL" if I let go of the gas a little bit, and press down on it again.
Old 19 Apr 2017, 03:06 pm
rob302's Avatar
Originally Posted by 2007ptc View Post
LMAO!!!!
this may help?
i'll keep it on track now.. sorry
2007ptc likes this.
Old 19 Apr 2017, 03:10 pm
no....not at all you will figure it out you are a smart guy!
2007ptc likes this.
Old 19 Apr 2017, 03:34 pm
lol
Oil pan into ground at 20MPH... Nice crack. Possible fixes? Breezer General PT Cruiser Discussions 10 29 Nov 2013 10:39 pm
