2005 A/C problem
Old 21 Apr 2017, 01:20 pm
Default 2005 A/C problem
I figured I'd get the ac ready for the upcoming summer. I vacuumed down the system for a hour, Started the car and added the first 12 oz. The fan is on, but the compressor isnt coming on. I tried jumpering the low pressure switch and the compressor isnt coming on. I checked all the connections. Checked the fuse. Any ideas? Pressure is really high also, 100 psi on the low side.
Old 21 Apr 2017, 03:18 pm
VsandFords's Avatar
Default Re: 2005 A/C problem
When the compressor is off, the pressures will equalize. 100 on the low side when it's not running is normal. When you say that you jumpered the low side switch, you are talking about the one on the drier, correct? If so, and you had the A/C on, then it should have engaged the clutch. I am also working on the assumption that your '05 is like my '01.
Old 21 Apr 2017, 05:23 pm
Which fuses did you check?
There are three; the dash fuse-block #7 (25 amp) protects the blower, it is OK as the fan is on.
The under-hood PDC fuse #11 (10 amp) protects the compressor clutch power through the A/C compressor clutch relay. If it fails, the compressor will not engage.
For a non-turbo
On the coil side of the relay, all these switches need to be closed in this circuit to operate the power relay:
Dash fuse-block #12 (10 amp) - A/C compressor clutch relay coil - PCM - A/C pressure transducer switch - A/C low pressure switch-climate control switch - ground
The turbo is slightly different on the coil circuit
Dash fuse-block #12 (10 amp) - A/C compressor clutch relay coil - PCM -A/C low pressure switch-climate control switch - ground
The turbo PCM has a separate circuit through a different design A/C pressure transducer switch.
Old 21 Apr 2017, 08:58 pm
For a non-turbo
The only one I didn't check was the #12 under the dash. I'll check it out tomorrow after work.
Is there a easier way to get to the high side port? I hope that engineer got fired for putting that down there like that!
Old 21 Apr 2017, 09:26 pm
Yes the one on the drier, I got nothing. When I turn the ac switch on the cooling does start like its supposed to.
Old 23 Apr 2017, 07:31 pm
So, I checked the relay. Its got power on the pins that should have power. Then I checked the compressor for power. Its got power to the coil, so the clutch should be engaged. I'm assuming I'm going to need a new clutch coil.
2005 convertible top problem Chef PT Cruiser Convertible Forum 10 20 Jun 2017 02:08 pm
2005 convertible problem DC1327 PT Cruiser Convertible Forum 6 21 Dec 2013 11:26 pm
2005 PT Cruiser GT Problem PLZ HELP!!! avaracer182 General PT Cruiser Discussions 1 19 Dec 2011 12:46 am
2005 Fan middle pin problem I_LIKE_my_PT Tech & Performance Forum 1 10 Aug 2011 08:14 pm
2005 Horn problem crzn45 Sound and Security Forum 1 11 Dec 2010 04:25 am
