NEW member/owner HELP
Like Tree6Likes
  • 2 Post By sanatanadharma
  • 1 Post By VsandFords
  • 1 Post By rckstein
  • 2 Post By CONNELLY698
Old 25 Apr 2017, 11:15 pm
Default NEW member/owner HELP
I just purchaced an '05 PT Cruiser touring. 88,00 miles for my daughter. Everything works except the rear liftgate. It has the touchpad. It will open with the key but does nothing with the pad. I have tested the pad with a multimeter and it is OK. I replaced the solenoid and the remote receiver module that is on the top of the dash. nope. There are two plugs on the solenoid and none of the wirse color match the Haynes schematic. The little plug has 10v across it (bat has 12.6v). The big plug has no voltage across it. I have checked EVERY fuse in the car and they are all good. Is there a relay that controls it? Is there a control module for it? I am pretty sure it is a power problem but I have no idea where the loss is. HELP
Old 26 Apr 2017, 12:37 am
Default Re: NEW member/owner HELP
Take a look at this thread:
Liftgate touchpad replacement
Old 26 Apr 2017, 01:32 am
I checked out my pad and it is good. also since all it does is crate a short I shorted the connector and it still did nothing. I feel a new switch wouldn't help.... thoughts?
Old 26 Apr 2017, 11:48 am
I believe that the lift-gate key cylinder is mechanically connected to the latch-release.
First check the lift-gate latch/ release motor operation.
It has a two wire connector. The black wire is ground and the light-green/black wire is power from the RKEM.
In normal operation, the lift-gate touch pad grounds a circuit that signals the RKEM to send power to the latch release*.
Try applying 12 volts to the light-green/black wire pin at the latch release.
The motor should activate (other pin must be grounded).
If not, the problem is there.
If the motor is fine, you need to check the wiring from the RKEM all the way back to the lift-gate. Check continuity at and between each connector.
At the RKEM, try grounding grounding pin #13 (brown/light-blue).
If the latch releases, then the problem is in the ground wire circuit.
Disconnect the RKEM connector and try applying 12 volts to the light-green/black wire at pin #16. If the latch does not release, the problem is in the power wire circuit.
The connectors along the circuit are C202 and C302.
C202 is a 26-pin white connector behind the left kick panel (forward of driver's door).
C302 is a 12-pin white connector behind the rear left speaker cover.
The wire harness from body to lift-gate is a weak point because of the motion of opening and closing the door. Perhaps a wire broke.
*This touch pad circuit has a brown/light-blue wire to the RKEM and a black wire to ground. The brown/light-blue wire runs through the same C202 and C302 connectors to pin #13 at the RKEM.
rckstein and VsandFords like this.
Old 26 Apr 2017, 11:57 am
VsandFords's Avatar
I never try to follow sanatanadharma with his electrical knowledge.
Welcome to the forum from Texas.
rckstein likes this.
Old 26 Apr 2017, 12:42 pm
rckstein's Avatar
HE IS THE WIZARD!
VsandFords likes this.
Old 26 Apr 2017, 12:50 pm
That is completely awesome electrical advice believe it or not I actually can follow exactly what you're asking me to do and when I'm off tomorrow it's time to get out my test leads on my little 12 volt power supply and start running some test thank you so much I can already tell this form is going to be an awesome resource
Old 26 Apr 2017, 02:32 pm
rckstein's Avatar
Please go to the Welcome New PT Cruiser Members section and introduce yourself and tell us about your PT
Old 26 Apr 2017, 03:15 pm
I'e had several ground wire problems with a few PT Cruisers, You can always add a body ground near the problem device.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
New member and PT owner speedbottom76 Welcome New PT Cruiser Members 14 24 Dec 2016 05:47 pm
Hello!! New Pt Owner and Member!! 04limitedturbo Welcome New PT Cruiser Members 13 29 Aug 2014 01:31 am
New member, new GT owner Jeffz General Turbo Discussions 12 27 Aug 2014 01:53 am
Hello everyone! New member & PT owner Artista Welcome New PT Cruiser Members 10 19 Jan 2013 06:44 am
New member and owner saying hello! HYE_PTC Welcome New PT Cruiser Members 22 07 Aug 2011 08:58 am
