stripped intake manifold bolt
Like Tree2Likes
  • 1 Post By rcktpwrd
  • 1 Post By rsrocket1
Old 26 Apr 2017, 06:43 pm
Default stripped intake manifold bolt
Two of the five upper intake manifold bolt inserts seem to be stripped. When I attempt to loosen the bolt, they spin. I can feel the backside and it is turning.
Any ideas?
2009 Base PT. White. 115K as of 1/2016
Added cruise control.
Maintenance/Repair Achievements Unlocked: Radiator fan. Ball joints. Wheel bearings. Timing belt. H2O pump. Front Struts.
Old 26 Apr 2017, 07:56 pm
rcktpwrd's Avatar
Default Re: stripped intake manifold bolt
Can you get the tip of a screwdriver on the brass insert? A little pressure on there should be enough to get the bolt to come free. If not you will have to pull the entire intake off so you can get better access to the brass insert, to be able to hold it somehow.
You could also remove the head of the bolt and drive it out, then use a longer bolt with a nut and washers...
chuzz likes this.
Joel
www.rcktpwrd.com
Old 27 Apr 2017, 08:31 am
rsrocket1's Avatar
If they spin, they are not holding the bolts to the manifold. Remove the unstripped bolts and gently pull the manifold up. The inserts should pull right up with the bolt.
Look here
Get some JB Weld. The inserts can be glued back in with some careful work.
VsandFords likes this.
Stripped nutsert on lower intake vanman General PT Cruiser Discussions 10 27 Mar 2016 06:50 am
stripped transmission bolt holes. How to repair? Flash619 General PT Cruiser Discussions 21 28 Mar 2015 08:22 am
Size of bolt in the back of intake manifold?? postbeauty General PT Cruiser Discussions 7 09 Jan 2014 06:55 pm
Intake bolt stripped lostinoregon Tech & Performance Forum 8 16 Dec 2012 01:39 am
wtb 05-up upper intake manifold, throttle body, intake hose to turbo,aircleanor lid 1autodr Classifieds: Want To Buy 1 24 Feb 2011 05:15 pm
