Missfires
Like Tree4Likes
Old 27 Apr 2017, 07:21 am
Default Missfires
Im working on my sister-in-laws 2004 pt with 130k miles.
It is misfiring randomly every few minutes at idle and seems to continue after acceleration from a stop sometimes. When its not puttering it is ideling smooth. I just replaced the radiator 2 weeks ago because of it stalling an misfiring with the AC on. Thats better now, while it hasnt stalled yet its very close. I got a misfire and camshaft sensor code but it hasnt thrown any since yesterday when i replace the camshaft sensor. I know the spark plug wires are first suspect on this car, but i replaced them last year(jan 2016) with bosch 09477 wireset, as well as plugs champion RE14PLP5 (7440). Intake manifold was also replaced then. This was all part of a timing belt job last year at 105k.
I took apart the intake manifold and cleaned the the usual suspects on it. Nothing obvious in the coolant or oil, but havnt done a change lately. There was an unusual amount of oil in 2 of the spark plug chambers last night when i was cleaning after the camshaft sensor didnt resolve the issue. I pulled the plugs and removed that oil, plugs looked ok.
Im leaning toward coil pack, then wires. Or maybe fuel filter? Water in the gas? Im at a loss but im really hoping its not a headgasket or valve issue.
What should my next step be?
Old 27 Apr 2017, 07:31 am
Default Re: Missfires
Maybe try cleaning the throttle body and put a bottle of Techron fuel injector cleaner in the tank. But what about the plugs? You state that you replaced them last year, but have you pulled one to see what it looks like? Plugs can tell you a LOT about what's going on with an engine.
Old 27 Apr 2017, 07:57 am
I ran fuel injector cleaner in it less than a month ago. I did clean the throttle body and could do some more i guess, but honestly it seems to be working fine. When it sputters at idle with the air filter off you hear a huge inrush sucking noise of air being sucked in briefly when it starts to misfire... this is probably not helpful info though.
The plugs looked ok, if not a bit on the white side.
Old 27 Apr 2017, 11:45 am
Did you clean the camshaft magnet, make sure its not cracked. Don't over tighten if you take it off, it has locating pins.
Intake gaskets could be causing miss fires, only way to check is remove it.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 27 Apr 2017, 01:09 pm
Currently working on it now. Going to install new valve cover gasket. But ohm'ed the spark plug wires and 2 seem bad. There's also a crack in the bottom of the resin for the coil pack so im about to test it.
Old 27 Apr 2017, 01:44 pm
Coil tested out fine as everyone on here says, they dont fail unless its obviously busted. 2 of the wires have high resistance (several k Ohm)however and these were lifetime warranty off amazon but not sure how to redeem that since they are currently unavailable now. Suggestions on new wires?
Old 27 Apr 2017, 03:12 pm
Handy_Cruiser's Avatar
MSD 32689 8.5mm super conductor spark plug wire set. These are heavy and well made. May be overkill on an everyday driver. But it's a case where you can have a very good high quality product for not too much more than an average quality product.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
NitroPT likes this.
Old 27 Apr 2017, 03:38 pm
This is not exactly accurate. Everyone in this case on forums does not get an election won. The only way to health test a coil is by using an oscilloscope while operating on the engine. The DIY test is a simple fail run test and not a complete that you must do under a load and different engine speeds.
So what I am basically suggestion is dont necessarily rule out replacing the coil pack!
JDK52 likes this.
Old 27 Apr 2017, 03:58 pm
Fk5 Fk5 is offline
$14.50 a wire?!?! Yikes!
They aren't even custom length. OEM wires are different lengths for cylinders 1&4 (longer) and 2&3 (shorter). I've paid that much for wires, but there were 9 of them!
2003 GT 5 speed
162,000 miles
Old 27 Apr 2017, 04:06 pm
rckstein's Avatar
The OEM set on my PT are all the same length.
NitroPT likes this.
