Break light fuse blowing
Old 27 Apr 2017, 07:53 am
Default Break light fuse blowing
In my 2005 pt for the past year ive had the break light fuse in the engine compartment blowing probably every few weeks or months. I took the back lights off and looked for bare wires but they all looked great. Next step i guess is take the plastic off on the hatch. Is this a known issue where i could hunt down a troubled spot?
Old 27 Apr 2017, 07:58 am
VsandFords's Avatar
Default Re: Break light fuse blowing
If you have a hitch and are wired for trailer lights, start there. If not, let the search begin!
Old 27 Apr 2017, 09:50 am
Nope no hitch
Old 27 Apr 2017, 09:56 am
VsandFords's Avatar
My only suggestion now is to start at one end and inspect the wires as you go.
Old 27 Apr 2017, 10:47 am
LionPT's Avatar
Have you checked the tail lights themselves..??
They have a tendency to crack & let water in blowing out the bulbs.
You didn't mention bulbs, but it's possible it's blowing your fuse.
Old 27 Apr 2017, 11:09 am
I pulled out the tail lights and looked the wires over and did replace a half out bulb.... I didn't think that could blow a fuse however. Ive never seen water get in them before either.
Old 27 Apr 2017, 12:14 pm
Do check the CHMSL (center high mount stop light) unit!
The 2005 PT44 (four-door) brake-light circuit is as follows:
Battery, PDC fuse #12, brake-light switch, wires, connectors and splices, bulb sockets, bulbs, grounds.
There are two separate grounds. The CHMSL and left lights are grounded in the left rear quarter; the right light in the right.
Of the three connectors, C106 is a known source of electrical problems.
It is the large grey connector behind and below the dash fuse-block; on a bracket next to the large white connector.
C202 is a white connector under the left kick-panel, forward of the driver door.
C302 is behind the rear-left speaker cover.
The brake-light circuit wire color is white/tan from the brake-light switch all the way back to the bulb sockets.
Help! My 01 PT keeps blowing Fuse #13 Hugh_Jorgan Tech & Performance Forum 7 09 Jul 2015 10:50 am
BLOWING FUSE 13 hillbilly678 General PT Cruiser Discussions 7 04 Jul 2012 04:45 am
fog lamp fuse blowing smilanatu Tech & Performance Forum 13 19 Jul 2009 11:07 am
pt blowing fuse to shut off engine ? bruinspt Tech & Performance Forum 2 23 Jun 2009 10:32 pm
Fuse Blowing Zoomer General PT Cruiser Discussions 2 19 Jun 2009 11:48 pm
