PT Cruiser Overheating
Like Tree5Likes
Old 03 May 2017, 09:57 pm
Default PT Cruiser Overheating
My 2007 PT Cruiser has been overheating. The problem has grown worse over the past month or two. It was intermittent, with the gauge going only a little bit over the halfway mark, but now reaches the 'H'.
I flushed the coolant system and replaced the thermostat. A bit better, but the problem persists.
So I took it to the dealer, who diagnosed the following:
-radiator leak
-fan fails to turn on at low speeds
This seems consistent with the fact that the overheating generally happened at low speeds rather than travelling on the freeway.
The dealer does not think it's a head gasket. But the mechanic indicated there is a valve gasket leak, as well as a broken motor mount.
I'm considering whether to do the repairs. My question is, given the high mileage on the car (around 177,000) and the cost of repairs (parts and labor for fan and radiator would be around 1400), is this something worthwhile?
Also, as money is tight right now, I have to wonder whether there is a connection between the valve gasket leak (not covered in the parts and labor quoted above) and the overheating. I suspect that's a slow leak, since I have not lost a lot of oil of late. So what I'm wondering is whether replacing the radiator and fan would fix the overheating and allow me to get perhaps another several thousand miles out of the car. I was not planning to take on more debt for a car loan or to save up for another vehicle until after the beginning the year. (Long story, but I've had a lot of expenses of late.)
Thanks in advance for the advice.
Old 03 May 2017, 10:19 pm
JonN's Avatar
Default Re: PT Cruiser Overheating
$1400 for parts and labor? Are these parts gold plated? That seems awfully high. I had both my radiator and fan replaced with aftermarket ones by my mechanic for $447. Head gasket issues should be able to be ruled out with a compresion test. I would try to get a quote from someone else.
By valve gasket you mean valve cover gasket, right? That is something that also shouldn't be too much to replace. As far as the engine mount, do you mean the center mount? Or the upper and lower torque struts which some people refer to as mounts? If it is one of the torque struts those are pretty simple DIY jobs that should be quick.
Assuming the diagnosis on your cooling system is correct and all other components are fine, your PT should be fine.
BIG RED '01 LE 193K and counting!
Vision Cross 16x7 Rims, 205/55/16 , Painted Calipers, Spoiler, CAI, Pioneer DEH-64BT head unit, NEW Skar SKv2 200.4 amplifier 2 RF P2D2 12's, RF P1T-S Tweets, RF PPS4-6 Mids, RF 6x8"s, AudioControl 24XS crossover/line driver
Newest Car
2016 Jeep Patriot Sport 2.4L 6 speed auto 92k
NRS brakes and energy suspension bushings
Pioneer DEH-X9600BT head unit, Bē Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 03 May 2017, 10:23 pm
rckstein's Avatar
Welcome to the forum
Have you had this vehicle since new? If so, has the timing belt ever been replaced on it? If not, hard to believe that you could have that many miles on the original belt.
If the timing belt has not been replaced, it is way overdue. To do the timing belt work and the other components (timing belt, water pump, tensioner, idler pulley, cam seals, crank seal, center motor mount with new bolt) is going to be about $1000-$1500, on top of whatever issues you are already facing with your PT.
But if it does overheat to the point of causing severe damage, it may be difficult to justify costly repairs, as the car may not be economical to fix it at that point. The ideal plan is to stay on top of small issues before they become huge problems.
Old 03 May 2017, 10:41 pm
I replaced the timing belt and water pump around 30,000 miles ago, so those parts should be ok.
I thought the $1400 quote was high. This dealer usually seems to be on the high side depending on the type of work. Not sure why.
Assuming I opted to do the work, whether through the dealer or someone else, what do you think about the other issue (valve--not HEAD-gasket)? Is there a connection between this an overheating?
Old 03 May 2017, 11:17 pm
rckstein's Avatar
You have to get the overheating under control before it causes real damage. The dealer is awfully high on the radiator and fan, and that's most likely because they will use OEM parts.
Did they do a full diagnostic on the fan and tell you the fan was actually bad for one or both speeds?
If the fan and radiator need to be replaced, and you can't do the work yourself, you might try getting an estimate from say Goodyear. They will most likely use NAPA parts and it could be about 1/4-1/2 of the dealer price. On the fan, it's best to get one that includes the relays and wiring harness, if you reuse those parts from your old fan, you may be transferring problems to the new fan.
If they replace the valve cover gasket, be sure they also replace the O-rings around the spark plug wells.
Old 03 May 2017, 11:35 pm
Last fall I replaced radiator because of top tank crimp leaking and radiator cooling fan a few months before that, Installed them my self in less than 4 hours and way under $200 for parts.
I think it all comes apart with a 10 mm socket and pliers to release the hose clamps. I used a regular and deep well 10 mm on a 1/4 drive ratchet
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 04 May 2017, 12:24 am
I think the estimate includes replacing all hoses, too. Is this something really necessary if the existing hoses are intact?
Old 04 May 2017, 05:53 am
Along time ago and far far away..... antifreeze caused the hoses to soften and swell and require replacing, I cannot remember the last time I found a bad hose, haven't changed one in years. If its not rubbed through or cut, use your own judgement.
I'm sure the parts store or dealer would be glad to see you.
73 Charger SE
01 Sebring flip
Old 04 May 2017, 07:06 am
Where do you live? I'd be willing to do all of that for you for half that price and that would INCLUDE the parts. You really need to call a few independent garages in your area and stay the hell away from that dealership. They're screwing you without even taking you out to dinner first. And I didn't see any mention of a new thermostat and gasket. You'd better add a couple hundred more for that at the stealership!
thecabinguy likes this.
Old 04 May 2017, 09:52 am
rsrocket1's Avatar
The fan and radiator are essentially the same job. You have to remove the fan (6 bolts and the power plug) to get to the radiator (another handful of bolts and the top/bottom hose). I was reamed $140 for a radiator at Autozone, but I needed it right away. If I had the time, I would have bought it mail order for about $40-$50. The fan is <$100 shipped or about $140 locally. It's literally a 1 hour job so even if a dealer is charging 2 hours at $150, you are still getting taken.
You have to disconnect the hoses anyway to get the radiator out so sticking a new hose in simply means unclamping the other side and replacing the $10-$20 hose with a new one.
The "motor mounts" are probably the passenger side engine torque struts. That's another 1 hour job and $20 in parts (much more if you buy OEM). That is a completely different job so you can hold off on that if you can tolerate the engine rocking back and fort during acceleration and that's only if they are completely torn like mine were.
Be sure that both top and bottom torque struts are replaced
Tags
overheating, pt cruiser 2007, radiator
PT Cruiser Overheating evonna_21 General PT Cruiser Discussions 39 22 Apr 2017 05:59 pm
Overheating Cruiser TheDarkAvengerX Tech & Performance Forum 8 17 Feb 2017 01:15 pm
06 Cruiser overheating Wutliss420 Tech & Performance Forum 1 21 Feb 2013 03:43 pm
Cruiser overheating rdpar General PT Cruiser Discussions 2 05 Jul 2012 09:09 pm
My Pt Cruiser is overheating JonS Tech & Performance Forum 4 18 Jun 2012 05:58 am
