Why OBD not respond?
Like Tree5Likes
Closed Thread
Old 07 May 2017, 10:53 am
Default Why OBD not respond?
Hi.
My PT is trouble with transmission and I notice P0700 code on dash.
So, I go to dealer and ask for sub code for P0700.
Dealer connect OBD3 and Said "It not working. You must change your TIPM."
Is really true? I can't understand. dealer said also "Price is about $700 over.."
And another question.. My center fascia goes hot when I use heated seat or
turn on another electrical device.
Thanks for reading this.
Old 07 May 2017, 11:09 am
Default Re: Why OBD not respond?
Have you tried resetting with an OBDII Scan Tool to see if it comes back? Sometimes if your battery voltage goes low enough it will give you random codes.
More information is needed if the P0700 comes back.
What year is your PT Cruiser?
How many miles?
When was the last time the transmission oil filter and oil changed?
Old 07 May 2017, 11:39 am
JonN's Avatar
Not sure if I am right or not, but many times when I've seen OBD2 scanners unable to communicate with the car, the car had a bad cigarette lighter fuse and upon changing the fuse it worked fine. Not sure if this would be the same for a PT cruiser, but it's a quick check.
2016 Jeep Patriot Sport 2.4L 6 speed auto 97k
NRS brakes and energy suspension bushings
Pioneer DEH-X9600BT head unit, Bē Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 08 May 2017, 07:38 am
To ptcruisersteve
Have you tried resetting with an OBDII Scan Tool to see if it comes back? Sometimes if your battery voltage goes low enough it will give you random codes. - Battery voltage not low i think. everything normal except code and OBD connect..
- P0700 code comes three times and PRND indicator blink sometime.
When I stop my engine and start again, symptom goes away for a while.
What year is your PT Cruiser? - 2006
How many miles? - about 75000 miles.
- two month ago.
Thanks very much for your comment.
Old 08 May 2017, 07:41 am
To JoneN
- When I check TIPM, dealer check every fuse and said every fuse good.
But I will check cigarette fuse again. Thank you for comment.
Old 08 May 2017, 07:59 am
rckstein's Avatar
Last edited by rckstein; 08 May 2017 at 12:36 pm. Reason: Removed-Because some other member wants to control the entire forum
Old 08 May 2017, 11:02 am
Originally Posted by rckstein View Post
You could try going by an auto parts store (Pep Boys, AutoZone, O'Reilly's, etc) and have them do a code read to see if they are able to pull up any codes.
Is the MIL currently on?
Try this reset procedure, it's a little bit different than just disconnecting the battery:
My PT is currently experiencing some of the same symptoms as yours, and I have the same model as you. My UG is showing trouble codes of P0700 and P0562, and occasionally the airbag light may come on for a few seconds, but they have not yet tripped the MIL.
It had been shifting a little rough lately and I had the transmission fluid exchanged and the filter replaced. It does appear to shift much smoother now.
I've cleaned the battery terminals and reseated the PCM connectors, so I guess I'm in a holding pattern until an actual failure of a component or the MIL actually trips.
Thanks for comment.
I.don't understand the word MIL and in image you tag two batt cable touch together????
I wann know about that.
Old 08 May 2017, 11:22 am
rckstein's Avatar
Last edited by rckstein; 08 May 2017 at 12:37 pm. Reason: Removed-Because some other member wants to control the entire forum
Old 08 May 2017, 11:31 am
I DO NOT RECOMMEND.........
The battery disconnect is NOT the way to do any ECU/PCM/TCM,Monitors, etc., in the case of any diagnostic issues that you are trying resolve . It only will prolong and in many cases complicate the processes to find the issues.
If you or anyone is having P0700 codes or any issues out of the normal transmission operations I suggest to go to a Transmission service shop to have your transmission and the controller checked.
Old 08 May 2017, 11:49 am
rckstein's Avatar
Last edited by rckstein; 08 May 2017 at 12:38 pm. Reason: Removed-Because some other member wants to control the entire forum
Closed Thread
Tags
tipm
please respond !!!!! i have a question tthrift Vendors & Buyers Forum 9 26 Aug 2004 10:00 pm
