switch question??
Old 09 May 2017, 04:01 am
Default switch question??
one question
will a key switch cause a no start? motor turns over and stutters then dies
checked spark and its getting spark when its cranking but still wont start even with starting fluid.
1.anyone ever had a crank with spark and no start ? I would think a bad key switch would not let it fire?could it still crank and fire with a bad key switch?
06 non turbo.
Old 09 May 2017, 06:22 am
svtnos's Avatar
Default Re: switch question??
sounds more like a fuel problem
2003 PT Cruiser limited edition
Old 09 May 2017, 09:05 am
VsandFords's Avatar
Timing belt jumped?
Old 16 May 2017, 08:20 am
cant see that being it cause it did this a week or 2 ago then just started right up like nuthing was wrong?..I"m just trying to see if the switch could act like this before I replace the fuel pump
Old 16 May 2017, 12:30 pm
I would check to see if there is fuel pressure before changing the pump.
Old 17 May 2017, 12:56 am
Are you getting a strong spark from all 4 cylinders?
Old 17 May 2017, 07:02 am
I'm with Steve on this one. What color is that spark? If it's a kind of yellow/orange, then it's not hot enough. You need a nice blue/white one. Enough to knock you on your ass if you're not careful! Maybe a weak coil.
Old 17 May 2017, 07:48 am
Handy_Cruiser's Avatar
Look for trouble codes first. A bad SKIM, cam sensor or crank sensor will do this as well, but usually throw a code. Also, a slipped timing belt sometimes throws a cam and/or crank sensor code too. Weak fuel pressure will often throw a Lean Condition code. Slipped timing belt will often show a reduction in cylinder compression, but doesn't always throw codes.
Old 20 May 2017, 03:18 pm
ok sorry guys I been swamped here so its been setting..I bought a pressure guage and my fuel line unhooks on the left side back by the fire wall..I clamped the pressure guage on the line from the pump,,cause the kit didnt have a way to do it inline..
when i turned the key on it jumped up to 60lb..and stayed when cranking?
is this a ok way to test the pressure ? and is that about right?.
still cranks and sometimes a stutted but no start,,getting spark on all 4 cyl..
Power Window Switch Question soonercruiser Tech & Performance Forum 3 24 Dec 2013 10:24 pm
Clutch Switch Question Aij29 General PT Cruiser Discussions 0 30 Nov 2012 05:51 pm
Fog light switch. question Petermr Tech & Performance Forum 1 28 Feb 2012 10:32 pm
dimmer switch question ptguy69 General PT Cruiser Discussions 7 01 Jun 2011 12:49 am
AC switch replacement question BeerBurner Tech & Performance Forum 7 01 Jul 2009 08:57 pm
