Car won't crank and fuel pump won't turn on
Like Tree5Likes
Old 09 May 2017, 12:15 pm
Default Car won't crank and fuel pump won't turn on
I have a 2006 PT that my brother gave me.
He had an error code saying cam sensor. He replaced the sensor but now the car refuses to even turn over nor will the fuel pump kick on.
I've cross jumpers the solenoid after priming it and she'll fire and run for a second or 2 and then die.
I've switched relays around thinking the starter relay may be bad.
I haven't been able to find a wiring diagram for the 2006
Old 09 May 2017, 12:25 pm
rckstein's Avatar
Default Re: Car won't crank and fuel pump won't turn on
Welcome to the forum
Here's a link to the Service Manual:
https://www.manualslib.com/manual/81...er.html#manual
Old 09 May 2017, 12:59 pm
VsandFords's Avatar
Welcome to the forum from Texas.
Old 10 May 2017, 03:15 pm
JDK52's Avatar
I have had a similar situation with a failed crankshaft position sensor being the cause.
Anyone else had similar ?
Good luck and please post back when you have it solved.
Old 10 May 2017, 04:47 pm
Where'd you get the sensor? If autozone or advance, it's probably a piece of crap. I used to work for both and saw numerous returns on defective sensors out of the box. Even if it were the cam sensor, with an extended period of cranking, it SHOULD start. JDK might be on to something with the crank sensor. First, run the codes and see if anything else shows up.
JDK52 likes this.
Old 11 May 2017, 01:40 am
If it was cranking before you replaced the camshaft sensor I would suggest putting the old sensor back in and see if it cranks. Don't start replacing other parts without doing a complete diagnosis first.
rckstein and JDK52 like this.
Old 11 May 2017, 06:39 pm
Edit delete.
Old 11 May 2017, 06:41 pm
rckstein's Avatar
Originally Posted by 03PTCrewser View Post
Check fuses 1st then try swapping ASD relay for Air Conditioner solenoid relay in the PDC. Also swap starter relay for horn relay. Confirmation by substitution. Takes 5 seconds, no money spent. Most relays in there are the exact same part number, so no harm will come of it. Doesn't hurt to make sure battery is fully charged before moving on deeper.
I think you may be talking about a Gen1, the OP has a Gen2.
03PTCrewser likes this.
Old 12 May 2017, 02:15 am
Security system?
Old 12 May 2017, 08:16 am
Security system?
Check to see if there is a red security light on the dash that is staying on when you are trying to start it.
What engine trouble codes are you now getting with the OBDII Scan Tool?
What is the part number of the Camshaft sensor you put in the Pt Cruiser?
won't crank or start/delayed turn over. PaulEcoli Feedback and Support 2 30 Apr 2014 05:22 pm
New fuel pump, but now no fuel to front? bundixlake Tech & Performance Forum 14 21 Mar 2014 09:41 pm
No Crank no Fuel No spark madoublet863 Tech & Performance Forum 9 28 Oct 2013 09:18 am
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
