timing belt change method?
Like Tree6Likes
Old 09 May 2017, 06:21 pm
Default timing belt change method?
08 PT 70000 mi, car is going on 10 yrs old, when should timing belt change be done?
Also, would there be any advantage to removing the right front fender to provide better access? Has this ever been tried or would it be a waste of time?
Old 09 May 2017, 06:38 pm
Default Re: timing belt change method?
No advantage to taking right fender off, but if you release the front bumper fascia on the right side and remove the headlight it gets a bit easier.
Busted_PT likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 09 May 2017, 06:53 pm
rob302's Avatar
it is not a hard job at all. it's just a lot of steps. i would not add any extra steps to the process. there is no reason to add more time to a seven hour job.
Busted_PT and VsandFords like this.
Old 10 May 2017, 02:47 pm
I'm at the midpoint in the job now on my 07 Pacific Coast PT. Had a few moments and now have the belt on but one tooth off so have to loosen all, readjust, tighten and spin it again to be sure of proper alignment and timing.
To save paying someone else a stack of hundreds, I bought the parts on RockAuto and a couple local parts houses, had to invest in a good balance pulley puller, and endure a bit of heat and wait for rain dry outs etc.
I'll do it again I think because once you have faced this lion the next one will be lots quicker. The car has couple of other things to do too but doing the belt and assessing the running and driving car will tell all all about the engine trans unit and the electrical system and brakes.
I found this forum and several U Tube videos to be great help in preparing for the job. Busted PT, Handy Cruiser, and others have contributed as well and I think I taught myself about a couple of things as well.The Haynes Manual is a good source for line drawings and info too.
70 K seems like way too soon even giving account to age of the car. If it has been well serviced and consistently on the road I'd like it even more. I'm all for replacing hoses and drive belts and if the car sat for the last 3-5 years I'd do the timing belt but if not, ?.
VsandFords likes this.
Old 11 May 2017, 03:41 am
OK, thanks for the replies, good to hear from those who have done the work.
Old 11 May 2017, 04:28 am
rckstein's Avatar
Maybe not add some extra steps to the job, but you should consider replacing some additional parts while the area is opened up: timing belt, water pump, tensioner, idler pulley, cam seals, crank seal, center motor mount with new bolt.
rockandroller likes this.
Old 11 May 2017, 12:28 pm
I would highly recommend you take good clear shots of the timing to reference later if need be. If you have issues a the end of things and need to rule out that. You can refer to the pictures and know without doubt that's good and move on to the next possible cause.
Old 11 May 2017, 12:34 pm
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
This will give you lots to think about when your following one of the how to's in this. Read carefully this and the other one before you start. Makes it a ton easer.
Old 11 May 2017, 07:13 pm
_PTGT03's Avatar
the secret is removing the right tire, inner fender well, lower the right front facia, remove right headlight.
remove the three left engine mounts while using a jack under the oil pan. discharge A/C system and remove hard lines for access.
get some special wrenches to access hard to reach bolts.
Old 12 May 2017, 10:18 am
rsrocket1's Avatar
I asked about evacuating and disconnecting the A/C lines before tackling my TB job too. I got the answer that you didn't really need to so I didn't. I don't have cruise control so I don't know how much easier it was without it but I really didn't have too many clearance problems by leaving the A/C lines connected. Maybe once or twice I used a credit card as a shoehorn to get something to slide past the A/C lines. A putty knife would have also worked. The real A/C caution is to make sure the alternator swings in far enough to clear the A/C canister bracket as you jack the engine way up to get to the iron bracket bolts. Chinese jigsaw puzzle anyone?
Last edited by rsrocket1; 12 May 2017 at 11:44 am. Reason: spelling of cannister <- canister
TIMING BELT CHANGE.....thanks to all. georgespt Tech & Performance Forum 1 04 Aug 2015 08:12 am
when to change Timing belt ? Ctown General PT Cruiser Discussions 13 18 Aug 2014 05:40 pm
Timing belt change BJ8Healeys General PT Cruiser Discussions 19 06 Jan 2013 04:26 pm
Timing belt change - is this possible? nx13688 Tech & Performance Forum 1 14 Oct 2010 06:50 pm
Timing Belt Change? tgibeau Tech & Performance Forum 10 07 Jun 2010 10:21 pm
