Pt drag car
Like Tree3Likes
  • 2 Post By rob302
  • 1 Post By NitroPT
Old 11 May 2017, 06:48 pm
Default Pt drag car
Working on a project to make the fastest car with a 1000 dollar budget. Only has to last for one race. 1/8th mile. Planning on gutting it and spraying it with nitrous. What can be done to make these things fast? GO!
Old 11 May 2017, 07:36 pm
Default Re: Pt drag car
You have the item N20.
Oh and your post should be quickest,
When talking Drag Racing it is all about Quick. Anyone can go fast ...eventually with a long enough road.
Welcome to the forum
Maybe you should really tell us a little more about your PT Cruiser then a budget of 1000. A sniper kit just ate 1/2 of that.
Old 11 May 2017, 07:51 pm
How much can be sprayed on a stock engine? Planning on doing head studs and new head gasket. Thinking of spraying a 100 or 150 shot
Old 11 May 2017, 09:16 pm
rob302's Avatar
i would recommend you look into the autolite AR series plugs. they have a ground back electrode and a recessed tip. they are less prone to melting and are great for one hit wonders like you're proposing.
i only mention this as i'm pretty good at melting plugs in my mustang and when i use these they don't melt half way through third like normal plugs.
Old 11 May 2017, 11:20 pm
Safely 50
You still have not said the year and model PT Cruiser??
Member's that know better about performance are going to be reluctant to suggest things with out basic information.
I doubt that you will be able to use any more then 75hp shot. Beyond that you will more then likely forced the PCM into limp mode.
Some of us have tried to increase to higher nitrous levels but it does require some calibration adjusting in the PCM. You will also need to use 100 octane fuel.
The use of a single electrode spark plug set at a starting point of .028- .032 for a 75shot.
Busted_PT likes this.
Old 12 May 2017, 12:06 am
It's a 2007, 2.4 liter non turbo. Also I have tuned a few v8 cars but never one of these. Does anyone know what tuning software I need?
Old 12 May 2017, 07:32 am
NitroPT does. There is a guy on here that has a drag PT. But it's a turbo. Spl something. Help on the name NitroPT.
Test Drag CREWZIN Testing 1 25 Feb 2005 09:55 pm
Drag strip get together in NJ ksquared11 Northeast PT Forum 36 03 Jul 2004 02:44 am
Drag Software macster Turbo Performance 0 08 Jan 2004 09:42 pm
drag race JaxPT Tech & Performance Forum 8 31 Dec 2003 09:50 pm
