E3?
Like Tree6Likes
  • 5 Post By rob302
  • 1 Post By gsw
Old 12 May 2017, 07:09 am
Default E3?
Anyone using the E3.66 plugs? Do you like them? Can you feel any difference?
Old 12 May 2017, 07:18 am
Default Re: E3?
You will find that if your plugs are pretty old, a new set of anything will make you PT or anything else feel better. A friend once said your not gaining HP. Your recovering HP from the use of warn plugs. As to the specific brand. It will come down to how long they last.
Old 12 May 2017, 10:16 am
rob302's Avatar
Default Re: E3?
i have no clue why anyone would want spark plugs where the tips had tomato cages on them. there's a lot of pics like this out there and most seem to have well under 10000 miles. if you get them, you should check them when you change your oil and see how they look.
i bet if all plugs came like E3's, the cool mod would be to cut two of the three legs off and file the remaining ground strap back... so they'd look like this:
Old 12 May 2017, 10:38 am
rob302's Avatar
Default Re: E3?
check this out..
Are these E3 spark plugs the real deal or just a gimmick? | Grumpys Performance Garage
Old 12 May 2017, 02:09 pm
Default Re: E3?
You can't make HP with plugs. But you can loose some if you don't get them set to optimum gap. If you burn off the electrodes like rob shows, I'm betting that you might eat a cylinder wall with all that metal. Just get you some good quality plugs and go on to the next thing.
Old 25 Jun 2017, 11:43 am
gsw gsw is offline
Default Re: E3?
I tried E3 plugs in my 2.4l engine and it made it run bad. had misfires and had to go back to normal plugs.
rob302 likes this.
Old 25 Jun 2017, 11:58 am
rckstein's Avatar
Default Re: E3?
Welcome to the forum
Please go to the Welcome New PT Cruiser Members section and introduce yourself
Old 25 Jun 2017, 03:36 pm
Default Re: E3?
.... ditto
