engine start issue
Like Tree3Likes
Old 14 May 2017, 03:40 pm
Default engine start issue
hello all, this is my first post and im looking for a small bit of help. I have a 02 pt cruiser that the timing belt had broken on. I went and got a new head and a new belt and installed it according to the haines manual that I also purchased. But now that it is reassembled it will not start. I have both fuel and spark and when I crank it over I get a single small back fire, but the engine never actually gets going. I have done this procedure on a single over head cam neon before with no issues, but was unsure if there was something I could be missing with this motor being a dual overhead engine(2.4 liter). Any assistance you guys might be able to offer is more then welcome thank you for your time
Old 14 May 2017, 04:06 pm
Default Re: engine start issue
Welcome to the forum. A few people that have done your kind of work sometimes mess up by putting the connections back on the wrong sensor. A couple of them will connect up and it may seem right but are wrong. I believe it's the camshaft sensor connection and the coil pack connection.
Here's a link that talks abut it...
http://forum.chryslerminivan.net/sho...sensor-harness
Old 14 May 2017, 05:26 pm
Thank you for the rapid responce and i wish it were that easy but like i said i do have spark wich i would not have if those 2 things were mixed up. 😭
Old 14 May 2017, 05:27 pm
very sweet lookin cruiser you have there though
Old 14 May 2017, 05:31 pm
VsandFords's Avatar
Welcome to the forum from Texas. The cams may not be lined up correctly. It took me 4 times before I got mine lined up. There are some great threads on here about timing belt replacement.
Go to Tech and performance, then go to "How to".
Old 14 May 2017, 07:04 pm
thanks Texas.....i have checked them they are perfectly lined up ....and i have been a member of neon.org for like 12 yrs lol i know to look through stickies before asking lol . its just frustrating cause i have gone over most of the common stuff that typically gets missed was thinking perhaps there was something im not typically accustom to that might be out of wack that might have been pt cruiser specific. have done this on multiple vehicles mostly neons and never had an issue like im having now
VsandFords likes this.
Old 14 May 2017, 07:58 pm
You may want to try using your old cam sensor and magnet. or unplug cams sensor and try But I suspect timing is off. Compression check??
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 14 May 2017, 10:30 pm
Make sure you are getting a good spark from all four cylinders.
As JoeX suggested do an engine compression check.
Is the fuel pressure at 58 +/- 5 PSI?
Are you triggering any codes?
Old 14 May 2017, 11:36 pm
no im not triggering any codes at this point and yes i did take the magnet from the old head .wasn't getting fuel or spark till i did that.but no i have not checked the compression.
Old 28 May 2017, 12:07 am
Ok thought I would give you guys an update on my findings so that perhaps it may help some one in the future. So the head I got was from an 07 pt cruiser and apparently event though it looks like its the same I found an issue that was the cause of all my problems. The timing dowel holes for the interrupter magnet was so out of sink that even though the car was physically in time,electronically it was not.Attached is a photo of the timing differences note in the photo both intake cams are set the same position.
Engine sounds like Diesel on cold start - engine clacking until warm mr_mahoney General PT Cruiser Discussions 30 04 Dec 2017 04:12 pm
Start Issue Sir_Rags General PT Cruiser Discussions 5 17 Oct 2015 10:56 am
Start issue lbeckm3 Tech & Performance Forum 2 09 Sep 2014 02:43 pm
no start/crank issue roaoro General PT Cruiser Discussions 6 23 May 2013 12:43 pm
Warm Start issue? crazyjoe General Turbo Discussions 2 14 Feb 2004 05:31 am
