New guy needs help
Like Tree4Likes
  • 1 Post By VsandFords
  • 2 Post By CREWZIN
Old 15 May 2017, 01:54 pm
Unhappy New guy needs help
did not know where to post this. low sensor error code 462. only fuel gauge is involved . right now? help
Old 15 May 2017, 02:16 pm
VsandFords's Avatar
Default Re: newbe. lost totaly tired of fixing my pt 2004 evry weekend . want a life
Welcome to the forum from Texas. I don't have an answer, someone will be along shortly with some info.
Old 15 May 2017, 02:33 pm
Default Re: New guy needs help
I put your post in the correct place. Here's an older thread that might help you...
P0462 Fuel Sender Voltage
Old 15 May 2017, 02:39 pm
rckstein's Avatar
My Gen2 occasionally has this code. The fuel pump was replaced a couple of years ago. When my UltraGauge trips this code, it will be when I am on a long trip where I have to fuel up enroute. Shortly after I leave the gas station, the code will trip. But it never shows up around town whenever after refueling and it hasn't ever caused any other issues. I haven't worried about it because it eventually clears on its own from the UG.
How did you know your PT has this code? Did the Check Engine light trip? You may just want to keep an eye on your gas gauge and odometer to see if you are getting your usual MPG.
Please go to the Welcome New PT Cruiser Members section and introduce yourself and tell us about your PT.
Old 15 May 2017, 02:41 pm
rckstein's Avatar
What just happened? The OP's original post has disappeared
Old 15 May 2017, 03:00 pm
VsandFords's Avatar
Crewzin moved it. I feel lost, like when you get home from work and the woman done packed up and moved the mobile home out of the trailer park!
rckstein likes this.
Old 15 May 2017, 03:07 pm
Sorry guys. Should all be back together again.
rckstein and VsandFords like this.
Old 15 May 2017, 05:32 pm
rckstein's Avatar
You sound like you're talking from experience on this?!
Old 15 May 2017, 10:13 pm
P0462 - Fuel Level Sending Unit Low Voltage Conditions
Possible Causes:
1. Faulty fuel level sensor
2. Fuel level sensor harness is open or shorted
3. Fuel level sensor circuit poor electrical connection
The PCM has detected the fuel level as being more than 100% for more than 4.5 minutes and triggered the P0462 code.
Has the fuel tank been worked on?
I would suggest checking the fuel level sensor harness. Physically check it from the PCM to the fuel tank and make sure its not rubbed through shorting to ground or open.
Old 16 May 2017, 09:50 am
Lightbulb Re: New guy needs help
thank you was having that thought to . its been going crazzy . not just off.
Tags
eropr code 462
