New timing belt, no spark no fuel
  • 1 Post By ptcruisersteve
Old 17 May 2017, 01:10 pm
Default New timing belt, no spark no fuel
Hi all I'm new to this site and new to PTs. I need help in getting my 2008 running. I'm about ready for the gas can and match.
Here is what I have done:
Replaced broken timing belt, water pump, pulleys
verified 1 up and valves closed
The picture is of the timing marks, 1/4 tooth off. Could not get any better.
After replacement no spark no fuel:
bore scoped all cylinder and valve are OK
checked crank sensor 5V on off when turned by hand
checked cam sensor got power and signal out
checked coil, no spark but power in and signal with diode probe
I believe I have 12V to fuel pump but I am not sure which wires are power, get 12V when key is first turned on
Have 100# and 120# compression on 1 and 4.
Turned over with valve cover off and both cams are turning.
Have check engine light when key on and tack when cranking
Checked fuses in fuse box, could not find any others
Have codes U1415 and U1414 which say unrecognized data which I don't know what that means.
Also have B212D, ignition run only input circuit open. Not to sure what that means either
I would hot wire the fuel pump if I knew which wires so I could eliminate that issue.
Though about putting on coil just not sure if that is the real issue with the U codes since it could be the computer.
I don't what to start throwing parts at the car and hoping for the best. I read the other post where people have spent thousands for a simple problem.
Thanks for ANY help that is offered.
Old 17 May 2017, 01:36 pm
VsandFords's Avatar
Default Re: New timing belt, no spark no fuel
Welcome to the forum from Texas.
First, sorry to hear about the trouble getting it to start. Was the Cruiser running previous to replacing the belt, or did you buy it needing a belt? Replacing the belt should not cause a no fuel/no spark situation. Check all of your electrical connections to make sure they are plugged correctly.
Old 17 May 2017, 02:42 pm
rckstein's Avatar
Originally Posted by carpenter View Post
Is your cam timing marks pic upside down? The writing on the cams at the center should be pointing upright so you can read them, like pic below:
Old 17 May 2017, 03:04 pm
rob302's Avatar
Switch the cam sensor and coil connectors. Seems to happen weekly here lately
Old 17 May 2017, 04:33 pm
U1415: ECM Data missing at Airbag.
NUMBER: 08-007-08
GROUP: Electrical
DATE: March 04, 2008
SUBJECT: No Engine Crank Or No Engine Start Due To Electronic Lockup Of The WCM / SKREEM
https://fortin.ca/en/qa/19623/faq-ts...r-wcm-no-start
The WCM might be able to reset by either disconnecting and then reconnect the battery negative cable at the battery, or by removing the IOD fuse (with the key out of the ignition switch) waiting 30 seconds, and reinstall the IOD fuse.
rob302 likes this.
Old 17 May 2017, 10:13 pm
The girlfriends daughter was driving it when it broke. I checked the connections but i will certainly check again.
Great point on the picture I will check it but I am almost positive of the writing being up when installed.
I apologize I don't know what IOD fuse is or the WCM. Thanks for all the input and if you think of anything else let me know please
Old 17 May 2017, 10:18 pm
here is a better picture
Old 17 May 2017, 10:27 pm
Added a better picture and the writing is up. Thanks for noticing that. I just hope I was not totally asleep when I put this thing back together.
Old 22 May 2017, 10:53 am
For sure the connections are in the right place. Leads wont reach other location and I had to repair the cam connection. Thanks
Old 22 May 2017, 10:55 am
Battery has been off for days with no change in the condition. I will try the other procedures and see what happens. Thanks
Argh! No Fuel No spark jere General PT Cruiser Discussions 11 24 Jun 2015 10:04 am
No Crank no Fuel No spark madoublet863 Tech & Performance Forum 9 28 Oct 2013 09:18 am
2001 PT cruiser, no spark, no fuel..?..?..? ozmr Tech & Performance Forum 9 19 Jun 2010 10:36 pm
good spark and fuel, but won't fire up! quintas Tech & Performance Forum 3 27 May 2009 06:20 am
Running Rough...New timing belt, water pum and spark plugs lanies_ptcruiser02 Tech & Performance Forum 15 05 Sep 2008 09:59 pm
